HKS cam gears do not have enough adjustment to smash the valves...
i have one on my RB25det and when i first put it on i didnt do it tight enough. after a month or so it slipped right ot the extreem and while the motor had less power it certianly did not smash vales or anything like that...
  • Replies 46
Shhh! don't tell people that. They won't be able to bash HKS products anymore
You cant argue though the HKS series one gears were decent.
The marterial was shit and the teeth wore down over time therefore making the Gen 1 gears the worst of the lot :banana:
bummer. my advice for ANYONE who fits ANY BRAND of cams gears is to check them 4 weeks after installation. being alloy there is always some 'give' in them. you tighten the bolts on installation but they can and do come loose. on one of my 32 GTRs. big build in japan. brand new crate motor, fully built from new, HKS turbos, 600ps all the good gear, cams, springs, head work blah blah blah. about 2 months after it was built we checked the cam gears. sure enough the bolts had loosened off. and these were tomei gears which run 5 bolts (i only use the 5 bolt jap gears, either tomei or trust). well worth checking.
Or just use stock modified gears :banana:
Were they HKS cam gears? Contrary to popular belief, not everything HKS puts out is even half way decent. I have seen their cam gears kill 2 motors. They only have 3 little bolts holding them in place. Really need to crank them little buggers down.
yeah, they really dont have a very god track record.... i went greddy because of this :banana:
I don't know what to tell you. I have seen two motors with bent valves that had an HKS cam gear which had slipped all the way to max adjustment. I doubt it was tuned that way and just a coincidence.
And HKS is really good at one thing with their parts. Adevertising. Nevermind, two things. Advertising and over charging for rebadging other peoples products.
bent valves. the pther problem i've seen with HKS cam gears is that shiny blue shit wears down/chips off, resulting in a tooth half the size of what it should be.
at this point, i'd guess its jumped a tooth (loss of power) then jumped another tooth and smashed valves.
I don't know why we are still discussing causes. the only way to suddenly get no compression everywhere is stuffed valves.
But you forgot the other very plausable option, some one stole his pistons.
lol very true....
maybe the gnomes that keep making hammering noises in my bottom end jump into his motor and took them
now we are getting some where, they stole his pistons and rods so they could do band practice in your sump.
This one time, at band camp............
Edited by W0rp3D
Stop being silly.
You can't have band practice without the lead guitarist and that would mean his turbo would be f**ked too.
  • 8 months later...
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
