What makes the hype?
1.Less than 2 feet IC piping with less than 150 degrees in bends.
Every bend or change in direction of air flow is viewed as potential flow loss. It is estimated at every 90 degrees(or three 30 degree bends)results in 1% flow loss. Compare competitors vs ASTRAY.
EXAMPLE
90+45+45+90+90+45+90+90+90 = 675 Degrees/90 = 7.5% flow loss just on piping
2.No battery relocation = No drilling big holes for intercooler piping
3.Able to keep front bumper support
Removing the front bumper support jeopardizes your engine bay in a front collision.
*NOTE: This 240sx would still be able to compete with an ASTRAY IC system as long as the radiator is unharmed.
4.Is not a V-mount IC
V-mount intercoolers are prone to heat soak. V-mount ICs lose efficiency when IC and piping become same temperature as ambient air. This often happens when car is not moving and engine bay temps heat IC.
5.Intercooler as direct cooling, no interferences from cars body parts.
https://www.sau.com.au/forums/topic/270299-ultimate-flow/#findComment-4598360
I am thinking that it isnt the ultimate flow.At high speed the air would bank up against it and rather go around as its an easier path
Yeah he needs to customize the bonnet to funnel the air through... lol...
would be better on the roof but...
https://www.sau.com.au/forums/topic/270299-ultimate-flow/#findComment-4598371
I like the theory about how removing the supports when installing a FMIC is somehow more dangerous than mounting an intercooler in the middle of your bonnet and obscuring a good chunk of your forward vision...
Looks stupid, IS stupid.
Edited by Iron Chef
https://www.sau.com.au/forums/topic/270299-ultimate-flow/#findComment-4598582
Looks as stupid as this guy getting around town with a pod filter sticking out from his bonnet on an old shitty Honda.
I shit you not, But there used to be a guy getting around Fairfield in an EXA Turbo with a hole cut in the bonnet and atmo BOV sticking straight out about 10-15 cm....That looked stupid.
I also seen several guys with holes cut in the side of front bar and pod filter partially sticking out.
WTF are these guys thinking ?
https://www.sau.com.au/forums/topic/270299-ultimate-flow/#findComment-4598805
Haha...
There's a guy in Gladdy driving a standard EA ford wagon with a pod filter sticking out the middle of the bonnet....
look totally stupid...
https://www.sau.com.au/forums/topic/270299-ultimate-flow/#findComment-4598814
More so Cooling will be at its maximum.
A good idea but interesting about what they said about the V-Mount intercoolers are prone to heat soak.
That image is not a V-Mount intercooler, I say it's a Top Mount, V-Mounts are like Front Mounts but on an angle, which is similar shape like a "V".
Designed to avoid damage if the front bar has been smashed off.
I find it hard to justify this intercooler system, as the Japanese have been using Front and V-Mount intercoolers in they D1 Drift Battles and other drift events.
https://www.sau.com.au/forums/topic/270299-ultimate-flow/#findComment-4599867
Coz he is shit at drifting and cant keep it on the track?
https://www.sau.com.au/forums/topic/270299-ultimate-flow/#findComment-4599874
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
