Old mans nav was good towing my car as well but I do agree with that darn flat spot from start.
I don't know if the later models (140kW) have fixed that issue or whether it's just the auto, but my Ti doesn't suffer from the poor low end torque and tows heaps better than my previous(125kW) 6 speed
  • 3 weeks later...
the patrol is now coming up 400 k and still tows every day. maintainence to date. brake pads and tyres. and, shock horror, i split the top tank on the radiator a couple of months back. a 400 dollar fix.
I reckon I should have recieved warranty for that.
Cvt worries me. Few issues in the US with them on the pathfinder.
I was reading that the ford towing speed is a "non enforceable" recommended speed and ford have come out and said as such apparently. Bit of talk about it on the caravan forums about it.
Ford stipulates it as a maximum speed of 80kph when towing over 1600kg in the towing capacities for the Falcon. That's the official information from Ford. And that is what any motoring body (RACQ, RACV) or caravan association will tell you.
Up to you if you believe that or some guys on a forum who claim Ford have apparently come out and said "nah, that just a recommendation".
Edited by hrd-hr30
perfectly accurate paraphrasing of what you said though, isn't it?
"Ford have apparently come out and said "nah, that just a recommendation""
vs
"the ford towing speed is a "non enforceable" recommended speed and ford have come out and said as such apparently".
New Jeep Grand Cherokee if you're looking at new cars. $55k for a Laredo diesel that tows 3500kg. They're an awesome car to drive towing or not. Best value for money in that price range.
Yes I sell them so biased but they're now comfortably smashing Prados so the proof is on paper!
We just sold one to Winton Raceway so they rate them!
The Navara is a good car ST onwards with the 140kw motor are solid but if you go the 6 speed manual you will always have to float the clutch in first gear as the ratio is quite tall especially if your towing close to its 3 tonne max (standard spec) the STX and STX550 are the gun choice though. 170kw and 550nM of torque through a very nice 7 speed auto is amazing to drive and tow with. I borrowed my old boss's STX550 and towed a car trailer with my GTR on it and it drove like it didn't have anything hitched to it
You mean the petrol only, light weight SUV aimed at the facebook and latte brigade?
Burn it
Burn it with fire!!
In reference to that though why do you think the new Y62 Patrol is petrol? Same principle as the new Pathfinder going Petrol only is because the UAE and USA have had these models for over 3 years now. In terms of a global market who cares about 23 odd million people wanting dictate what the majority of Nissans market is wanting?
They are actually a bloody nice car and to be honest when I was selling cars for Nissan most people who bought Pathfinders weren't traversing uninhabited worlds they were just using as a 7 seater they may take camping and sling a trailer or a camper behind.
Mark from Godzilla Motorsports bought a Ti one a few months back and he has the old diesel one swell and he loves it. Just food for thought. Just because it aint diesel doesn't mean its a shit car
vs
Not really, I was just reading in on the caravan forums. Was an interesting read.
My neighbor at work has one, it seems to spend most of the time in the shop getting fixed, the latest issue that he had with it was that one of the ancillary drive belts stretched (on a car that has done less than 10,000ks) and wore through the upper radiator hose, resulting in a rapid loss of coolant. He had the car off the road for nearly two weeks because of that as they didn't have a replacement upper radiator hose in Australia.
  • Like 1
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
