Just now, Hank Scorpio said:
Or if you enjoy punching the underside of the dash with your knuckles ever time you put the handbrake down.
That's quite a specific requirement but you gotta go with what works.
I have not looked back since getting a Audi Q7. Can tow car, trailer and several hundred kilos of tools, fuel and 3 mates like most cars going to shopping centre.
A good 10yo one is now probably under $35k.
  • 4 weeks later...
  • 1 month later...
Oil change every 7.5k $150
oil and filter every 15k $300
new rotors every 50k $500
pads every 30k 250
one satnave in 300k $1000
power steerin 1.5k
blower fan $400
new battery $550
water temp sensor $50
also did diesel pump belt and water pump at 200k ( this didn’t need doing but fingered I was in it for the long hall)
Every 100k gearbox and diff oils 1k
tyres last 40k(rear) 60k front
1 minute ago, ActionDan said:
Excellent info, much appreciated.
It's a turbo diesel right?
So when are you expecting turbo/injection pump to shit the bed?
Trans still happy?
Updated above post
still going it’s due for new oil at 330k will report back then
So the big ticket items are still to come.
I assume it's got direct injection as well so 6 very expensive injectors + injector pump is a good few K (same as any modern SUV now), turbo will be whenever it goes.
200 if you want to go off-road
q7 tows as well but much nicer when not towing
which is 90% of lyf
landcrusher always wins on resale cause Toyota fan boys but all the 50k landcrushers r 250k on the clock so just buy new as money wise it’s a similar depreciation
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
