  • Replies 417
yeh the pan is cement and slippy as a mofo, a lot of noise but not much smoke. although guys do try pretty hard and get some smoke going.
you cant do stand stills as you destroy the surface fyi.
Hi guys,
Yesterday I made the entry fee payment, but unfortunately I was unable to fax any info of the payment through... (The receipt number for the payment is- 128994)
If you need a fax of the payment, let me know and i'll organise one asap.
Thanks, and look forward to the event.
Had an absolute ball last time!!(Nov 08)
See you there,
Adrian M
Who else is pumped?
I've been watching all
videos and honestly cannot wait.
Just curious, but is that one 180 turn around the witch's hat still a part of the day?
The courses rotate every time, no-one knows what they'll be until they're posted up.
the 180deg around the cone at start of video is the long wang track. I think that stays the same. Only the skidpan courses change?
most likely will be coming up not sure if i got the money to enter though last time was so much fun though biggrin.gif
You should definatly come along Leigh, Cass and I need our drinking partners!
the long wang ran clockwise (the other way) last DECA.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
