i was just trying to scare everyone into thinking that ben had progressed faster then expected.
thats my rb25de head which is very similar to an rb20det head.
i will make a build thread when its on and working as i dont like to boast about things untill its complete. as it was i thought it was all good to go untill i found i had left a part of the manifold off during all of my test fitting. back to the drawing board for part of it but a night in the shed with ben and i working on it and we had it all sorted. its gonna be sick.
just another one to keep you all aroused
well i got to work on the car this weekend...hooray. Unfortinatully i spent most of it cleaning up the mess of it being left in the weather.
but the engine bay is nice and clean now. Brake booster also removed, i need to make a alloy plate to attach the master cylinder too
removed the rear 1/2 of hicas, and pulled the diff out so i can put the nismo centre in it.
waiting to be inserted
I'll be getting a set of wheel bearings next, and puttin the gtr rear hubs in, and abs front hubs in. And scouting the wreckers for a Auto VY commodore to rape and pillage.
Edited by sav man
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
