post up the Pre Christmas sale pics ben :D
Re the alloy sikaflexed on. if you need to remove them to you can easily like the original factory ones.
Plus, besides the weight of alloy, it's easy to work with.
Postman Damo and his black and gold sausage dog picked up and delivered some packages.
mmmmmm titanium.
nice welds
even got a silencer.
lightweight forged buddy club p1 qf. even got stickers and valves
GTR plenum and throttle bodies.
Edited by sav man
im considering the rb26 plenum... purely for low weight, how are you planning on fitting the plenum?? adaptor plate to the head?? weld plates on the rb20 runners?? PM me if you dont feel like sharing with everyone :huh:
it's no secret. I'm making an adapter plate up, but the plate is the easy bit, we learn't on damos, that you also need to modify the coolent bar that runs under the throttles, and the thermost housing. Not the end of the world though. Oh, it won't save much weight if any, the 26 setup is heavy as f**k.
I'm pretty much doing it just cause i can, to get rid of a heap of piping, and side entry plenums are waaaay to expensive.
im doing it for the same reason :huh: and by low weight i mean, lower... as in, to the ground.. not high and doubled up over the engine.. it will be low slung and im hoping to bring more balance with the exhaust manifold. with the way the engine rocks when revved, all the weight gets thrown to the turbo side.
side entry plenums are almost no existent for RB20... and the ones that do exist are too ricey.. i like the factory look of the rb26 plenum and the noise of 6 throttles... and it can support 400kw... my rb20 will never ever see that much power.
are you not worried about having the injectors 20mm further away from the head??
it's only 10mm, making the adaptor out of 10mm plate alloy. Also the uuber expensive blitz one takes the injector 25mm out from the head, and from all accounts that was a good bit of gear.
awesome... i was considering making the adapter plates and weld them to the stock rb20 runners to bolt the throttle bodies to... but your way is much cleaner and less hassle.. i thought you would have had to use 20-25mm plate, hence why i didnt want to do it, but if its only 10mm then thats not so bad.
btw, i love your exhaust!
im doing it for the same reason :D and by low weight i mean, lower... as in, to the ground.. not high and doubled up over the engine.. it will be low slung and im hoping to bring more balance with the exhaust manifold. with the way the engine rocks when revved, all the weight gets thrown to the turbo side.
If anything the further out that the injectors are the better. the more time the fuel has to atomise.
its one of thoes things that when you start looking you can see why we have built bens and mine the way we have. i started with the chop up the rb20 plenum option but that was way to complicated unless you was able to weld alloy yourself and wanted to do it that way. i made a plate that took about 5-6 hours to produce the first time around and most of that was the actual time setting up on jigs to cut the bits out.
Had you thought about the negative affects of the shorter runners on the 20? Bens planning on head work designed around this issue. my cars a different story as my engine is a 25de
the Plazman plenums are a grate option and have been proven over and over but they cost way to much for what they are. the price that we have been able to buy all the bits and make these for make them more worth while than the plasman.
yeh ive read as many articles as i can about the rb26 plenum on the RB20.. i will be doing as much headwork, and as much lightening and balancing as (financially) possible.. thinking solid lifters and big big cams (i know, its expensive).. so with a high high rev limit, and a high powerband, im thinking the rb26 plenum should be the go, as im not worried about bottom torque or street drivability.. the Zoom article showed the rb26 setup having great response, but lacking in the midrange compared to stock, but then picking up again later on. i dont know what turbo that was with though.
the sound of big cams and 6 throttles will make up for a lack of midrange.
Any pictures of the guts of the muffler. I have a trust ti exhaust, i grabbed the twin muffler version as its meant to be reasonably quiet..,but the ID of the rear muffler is only about 2.5" or so
I'm not very impressed with trust exhausts's, we lost 30rwkw with a 80mm trust peII on the Targa car. Our tuner says it's got restrictive mufflers.
i'll get some pics of the inside of mine tonight. Pretty sure mine is a custom build job, i got it's 2nd hand cheap ($880 delivered)
I didn't take any pics, but the muffler is 90mm through the guts
17x8 +28. the size restricted by the cadegory.
it should sound awsome. Just thinking what the good engine will sound like at 9000+ if i can be bothered building it.
the r33 is a far surperior car, and would be a good tarmac rally car if it was developed.
my car isnt too far off being tarmac spec...just needs the standard huffer and bonnet put back on....and oh I'd probably have to take off my silly rear wing too.
I thought about building it to targa specs...i just felt that it would be too heavy and lethargic with a standard turbo.
and not being on the Cams list didnt help matters lol
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
