holiday in northern tassie today :P
My radiator from race radiators rocked up earlier in the week. Fitted first time, and done exactly to my specs.
The airbox now has a place to live. and I made the pipes that go between the airbox and turbo. Just need to get them stuck together now.
Damo finished off most of the wireing last night, just need to get the fuel pumps wired and it will be very close to starting.
Steve the roofer finshed off the rear parsel shelf
And I got a package full of pogo sticks today :P
an initial re-valve is included in the price. as the current graphs don't look like they'll do the job. But I need to test it first too see if/how far it's out. They are bloody light
Yeah the BOV will be going on. It'll be done after everything else, cause i'll know where I can plum it then
Edited by sav man
omg omg omg omg... me want one!!
fantastic build buddy, keep up the good work :ermm:
anymore GMS ideas on the car?
Not really. 20 years is a long time, so most of it is old tech, or commenly used.
  • 3 weeks later...
