regardless of gauges or no gauges we have simply offered up some free info that has taken time and money to get. we used 2 different examples ect ect. take from it what you like. we will take that its simply better not to have to change engines the night before or during events (which is when we have had to do the last 2) and if your half capible a simple mod to the sump will stop that.
ironicly - My old drift team mate spun a bearing the first time he drifted after fitting an oil cooler. i blame the cooler 100%
You saying the cooler reduced the oil pressure to much?....
Woo aren't you installing one... Better touch wood!
The workshop putting together an external oil pump kit for me strongly advised against using an external filter block due to the poor design. Can't say I paid it much thought at the time given the number of folks running them but these guys do build a lot of race/drift motors.
Hypercry?
By external filter block you mean the block adapter or remote oil filter kit?
Also keen to know thoughts on the oil cooler causing failure!
I've got one coming with a built in thermostat
I think the comment was made with sarcasm... The same way the rest of us were taking the piss and blaming the gauges for wrecking motors...
I've been a bit slack cause it's been too cold. But the replacment engine is pulled down to install the restrictor, and mod the sump.
We had a high pitched squeel all event. We knew it was a boost leak, but considering everthing else we couldn't be bothered. After I pulled the car appart, I found the source of the leak. I had put a incorectly sized bolt clamp on, and it didn't seal evenly.
still considering it, i'd like to have a good look at one of them. But Damo and I have worked out how to VVT a normal RB20 head, just would come down to funds, and if this new engine needs it.
Did you consider a secret handshake V-Cam RB20 :) or are there elegibility problems with running a later model head, series of engine?
i had a bit of a think tank and dragged a coupple of old heads and bits up from storage and worked out that if the gains were there to be had it was easy enough to make vvt work on a rb20 head. without modding the head. i took a bit of insperation from the HKS V-Cam and sussed it all out. i supose people just dont see the point developing rb20 engines but for us having to fit within engine size rules we have/ want to think outside the square.
i think the whole project is just bringing good ideas from everywhere and putting them on one car.
the super f1 spec engine is has actualy suprised us both in its designe.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
