  • Replies 328
In
(...unless the gentleman flying in from Indonesia tomorrow morning to look at my car says, "Out")
BTW, can we go right past the destination like last year and get lost again?
Ford salesmen stood out the front to gaze at the lost sheep.
In!
but not in the mazda...stupid fixed seats, harness, no sound deadning, no heat or air con, no radio, I'll ride shotgun in the failvia plz spando?
Chubbeh, I'll be going in my fixed seat and harness :P
btw, definitely in for this :down:
sure do Dave!
And LOL @ Duncan!!
If things go right and I have my new daily driver, I'll bring that!
we'll see!!!!
no worries see you all then.....oh and I won't be bringing extras as yet sl!m, I don't have any friends and wy wife dosent like me..hehe
yep bring money on the day :domokun:
IN!!
Don't worry Terry you can cruise along with me and point out how much better the GTR WAS then my little N/A. Thats if u dont bring the OZFOZ mobile hehe
Thanks Dave, might take you up on shotgun and set up a swivel HandyCam. ;)
How's your suspension now?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
