  • Replies 60
I just came... again. Seen it in flesh a few times but just like porn, can watch it over and over again!
Kudos to you fellas for building the finest track attack car on this land!!
I want a full flying hot lap,,,none of this ending coming onto the straight malarky. We all know you two have it on your puters and an sd thingy.
Neil.
there were no real "hot" laps that day. it was tyre testing and sorting out a few little thing. mark was making his undies brown from about the second lap onwards due to those little bugs getting ironed out :blink:
wooster...i'll spew if you get to drive it before me!! lol
well i just broke a record i reckon....brisbane to darwin in just over a day and a half pulling a caravan! haha
average speed was above 130 and got booked at 137 at roma ( damn it).
highest speed was bout 150 on the highway the other side of mt isa!
but back to the r34 , yeah the tracktimes were good but there should be atleast another full second or so in it yet. the steering was locking up on some corners,
not sure whether this is due to rack being severely bumped out or fluid surge but need to look at it.
also need a better rear diff and a rear swaybar. and for eastern creek and bathurst in two months a taller diff ratio as it was hitting the limiter at the start /finish line on the front straight.
and of course, up the power which has not been touched since the initial tune.( but of course this wont be touched until the thing is handling as good as we can get it)
anyway hope to see you guys again soon
bloody hot up here!!
cheers russ
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
