  • Replies 306
Posted Images
There's generally lots of competition for that title, especially me this time. I'm coming with my daily, a CE Lancer with a few performance, but no handling mods.
I will be faxing my entry today.
Ahem! If my car isn't out of the panel shop or my Soarer doesn't get fixed I could be rocking up in an '89 Prelude LOL.
yours was one of the stuffed up forms so i got your name off your bank dep..
i have a blank fax also. sent today at 1155 from a private no. if you are not on the list and you send one today its probably you.
sorry blank fax was me. sent it the first time wasnt sure it went so did it again.
but all good. just saw the post and my name is added now.
WOOT. not long till im no longer a deca virgin lol
Probably dont remember me but I think we have met once at Heathcote when the Magna club was over there. Will be good to catch up again!
is 180sx ABS any good anyway?
nah they are absolutly shit house, had an accident once coz they didnt do what they suppose to, didnt u see when Roman and i where battling in the knockout round and i didnt stop and went threw the witches hat?? thats 180sx abs....i had a merc before the 180 and its abs was awsome...much stronger...
ill be happy with the grouping too
ill be losing my deca virginity also lol, it should be good.
Also just one last thing my mate wants to enter as well so does that mean all he has to do is fill out the application form and then on the day get the AASA licence and he will be right to go or does he need to be a member of skylines australia as well or any other car club.
Did you need me to re-fax?
Stagea ABS was shit with shit tyres and pads. Good rubber and good pads, and on the rare occasions it ABS's(emergency situations), it works sensationally....
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
