Hmm there's alot of thoughts on oils.... I'm no expert but seems like redline is the go if you wanna spend the $ or fuchs. But i've never used either.
Just did an 8ok change and put motul 8100, which seemed to be a recommendation of a few different posts.
Put Nulon trans fluid in as well, but never used the nulon engine oil.
It's australian though, so that's a plus :rant:
Edited by bayslideblue
I'm looking at different oils to use for my car,
need some recommendations, I'm looking at this one NULON
http://www.nulon.com.au/products/Full_Synt...sel_Engine_Oil/
thoughts?
Cheers
I use Motul 300v Chrono (10w40) in the Stagea.
I used the that Nulon 10w40 that you are asking about in my wife's Magna kast service. Seems to be good shit.
the Magna was burning a heap of oil and was very noisy (probably due to the 3L of oil that was left in it after 10,000kms). Put the Nulon in with their tappet treatment, damn quiet now and is great on startup. My wife says that the car is much, much smoother now.
Have had in the Stagea (all 100% Synthetic);
Royal Purple - good.
SHell Helix Ultra - ok.
Mobil 1 5w40 - too thin, engine didn't "feel" together, was quite noisy and I didn't have the confidence to push it.
Castrol Edge - not so good. Engine "felt" loose and was a bit noisier than I would have liked.
Motul 8100 - rubbish, could smell it burning, when I changed it (800kms after putting it in) a large mass of crap that smelt like charcoal came out.
Amsoil 10w40 - good.
Penrite Syn 0w50- way too thick. Felt like the intake pipe was 90% blocked off. Just didn't want to rev. (changed after 1100kms)
Motul 300v Chrono 10w40 - Best to far... by a long way too! Engine revs effortlessly, is damn smooth and is quieter than the any on this list. (too bad it costs so much)
I used to change every 5000kms, but I have extended that to every 10,000kms with the 300v.
Will be trying the Nulon 10w40 with my next service (2000kms away).
I say give it a shot. If it doesn't feel good (you will know), just change it. 5L of Nulon is what, $50?
Oils have different grades. Have a read of the different grades of full synthetic oils. "Full synthetic" is sometimes more of a marketing term than actually 100% synthetic. It may or may not be true.
Basically if I remember correctly, Nulon 300V was one of the few grade 5 oils, most other full synthetics are grade 4 (redline & royal purple i think) which is still pretty good, and then there are also a lot of grade 3 oils, which are still listed as "full synthetic" even though some of them are actually a semi-synthetic. This includes shell helix ultra...unless they've changed it recently...
Either way a synthetic oil will work well, just depends how critical you are. The average joe just sends their car to your average mechanic and their cars usually last the distance...so who knows...
"I use Motul 300v Chrono (10w40) in the Stagea.
Castrol Edge - not so good. Engine "felt" loose and was a bit noisier than I would have liked."
What grade Castrol Edge were you using? I had been using 5w 30 which was no good for my car but now on 10w 60 it is fine.
It really depends on what sort of climate that you live in.
If you live in cold climates then look for a lower figure with the W after it (5W) means that the oil flows as a 5 weight oil at 0 degC.
If you live in higher temperatures obviously this is less important, so you can go to 10W or even 20W.
The higher number is how the oil perfoms (flows) at 100 degC. So a 5W/40 acts a 5 weight at 0 deg and a 40 weight at 100 deg.
Now obviously you'd like it to run as a 5 weight at 100 deg eh? WRONG.... 5 weight oil at 100 deg is like water! 40 weight oil at 0 deg is like honey. So that's why we want a 5W/40... which is pretty consistent all the way from 0 - 100 deg C.
Keeping an oil in your engine too long will load it with contaminates. Mainly carbon, but also some metals (your engine wear!!). The non-synthetic oils use polymers to boost the viscosity at higher temps.
Imagine them like bits of styrene packaging suspended in the oil. As it get hotter they expand and make the oil thicker. Your engine is mashing them up though all the time.
So eventually they lose the ability to expand and do their job properly. Which is why you need to change them fairly often.
Pure synthetics don't do this.
I used to work for a Shell company. Once Shell did an experiment on a Cummins diesel, they ran it to destruction. It took about 630,000 hours. They didn't change the oil, or filters. They worked out that the replacement cost outweighed the maintenance cost by a staggering $60,000!
I once did an oil test on Mobil 1, for a customer. After 20,000 km, the test came back "This oil is as new".
It did have some contaminants but this was minor. The oil itself had not degraded. Good filters are worth far more than this brand or that brand.
Me I use Castrol Edge 5W/30 at the moment. If money wasn't any object it would be Mobil 1 every time. I'd probably go to 10,000km oil changes then instead of about 5,000km which usually turn into 7,000km oil changes!!
Remember all oils are tested if you don't understand what you are putting in your engine..... go read!! Start by Google-ing Oil Viscosity Chart.
The better you understand the more confident you will be.....
Hope this helped though.
i have castrol edge 10w30 and i know what Cam means when he says it sounds 'loose' and yes its noisier then before!
that said, it revs more smoothly (to me) and hasnt discoloured the oil so it appears to be doing its job.
im also thinking of going down the nulon engine oil path soon
I currently use Martini Racing Oil
Synt http://www.martiniracing.com.au/resources/...tini%20Sint.pdf
Martini is my current aswell! although that WAS my first service just last week.
seems to be running fine if not slightly better than before!, and it had Motul in it before Martini i do beleive. ;)
Synforce ProSYN 730 - 7.5w/30
http://www.synforce.com.au/synthetics.html
Queensland made for nissan motors. Was in my car when i bought it and found it good, currently running Castrol edge 5w/30 and find it poor in comparison...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
