spotted a black 32 on brunker rd at yagoona-ish area this afternoon. pretty sure plates were RR.32.GT. so so clean
i think i spotted this guy too last friday but it was a grey 32 and i think his plates were GT-32-RR so maybe it was some one completly different and just a weird that the plates were the same but different.
Spotted Chubbs, Anna and Mitch this arvo around 3pm
Also spotted a gunmetal 33GTSt with a kit about 5 minutes before, turning off the Great Western Highway onto Toongabbie Road...
On the way home from around Richmond today I saw a black wingless R34 on the M2/Mona Vale Road/Forest Way and...
A certain blue Audi with the number plates HAY 53Y on Mona Vale Rd (I think... it was along those lines, plates where also blue) :P
spotted a hot asian chick in a wingless silver R33 plates BCR-04P
roaming along Canterbury Road in Ashfield this arvo
hi or 'ni hao'/'lei hou'/'kornichiwa'/'sa was dee'/'aneyong asaiyo' if you're on here :D
Spotted a yellow R34 with a black bootlid and black front bumper pulling out of a service station on Blaxland Rd in Campbelltown last night about 9pm. Had stickers on the front door and a large GT wing on the back. Not really my cuppa, but that doesn't matter, does it?
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
