theres someone that moved a few houses down from me. yellow 33 gtr plates WAR13R or WAR31R. on this forum? and a 32 gtst that flies around my streets trying to drift etc. dont think he'd be on here though :blink:
and do i ever get spotted ????? :P:( :( lol
Prob Nick (Godzilla)
Spotted a white R33 S2 "BO.55.RB" this arvo on sunnyholt rd driving like a absolutely tool :)
and also a silver R33 S2 mins later, plate were "DR.33.GT"
oh yeah thats him, it had the hulk sticker as well lol
bit late but spotted a green stag around westmead area around 5.30pm fri arvo with sau sticker on it.
Spotted a white R33 S2 "BO.55.RB" this arvo on sunnyholt rd driving like a absolutely tool :D
Umm, I don't remember having gone anywhere on Friday afternoon because I had people over at my house... And my car was in the garage, so this is a bit of a mystery to me. Do I have a clone?
You sure it wasn't Thursday?
spotted a silver r33 gtst series 2, looked like it had blak starcorp rims with polished lip, and SAU sticker on the rear at Rockdale around 4:45 this avo
hi if ur on here, i was in the series 2 with carbon bonnet goin opposite direction :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
