Got absolutely owned by a Charcol R32 GT-R (with bonnet scoop) today turning onto Old South Rd heading towards Mittagong.
Sounded like sex.
Edited by Tai1or Made
spotted a certain red 180sx on the back of a trailer heading south along the M7 near the tolls just after 7 this morning.
Also spotted a pretty clean white 33 gtst on the m2, plates were pyro something etc
Mine. Plates are PYR 0IB. It was filthy, car looks so much hotter after a 4 hour detail wash and polish
I take it you where the black 34 GTR heading into the epping tunnel
Edited by ianjb
Sounded like sex.
Saw that guy the other day, did it have a loud ass exhaust? I was walking along the walking track and I heard him from 1km away. Lol.
Just spotted 2 x liners on Help Street in Chatswood
Gun metal R32 GTR with a SAU sticker on the right rear-quarter
Yellow R33 with White LM's (?) and a SAU sticker on the top rear window
Kind looked like R32 was raging at the slow ass infront of him lol
You guys were about 2 minutes apart from each other at the intersection of Help and Princess Hwy. I was looking down at everyone getting smashed with rain in the brown building on the corner lol
Spotted this dude fly into the canal today on my way home from work, went down to see if everyone was OK and help if needed but they went ape shit and started yelling at everyone and throwing shit so I just went to my car and left, I know it's f**ked up but people were trying to help and be nice dude.
the space saver on the rear says it all
sounds like nobody was hurt too bad if they could carry on like morons & throw shit at people :blink:
looks like the canal between campsie and burwood
Yeah its off croydon road croydon park on your way to campsie, the freakiest thing is that i was driving right behind him, he was driving fine until we got to that bend and he went agro or tried to drift it around the bend and lost it.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
