Unfortunately my poor eyes have to see that thing almost everyday as the Indian owner lives in my area.
He must also work or something on Elizabeth Street near Redfern as it's parked there alot too! Shocker..
Unless there's 2 of them :yucky:
white 34 gtt with gtr rims in APR today - coming out of creamery road onto the highway, SAU sticker rear right quarter window :D looked very nice.
was in the daily (yellow lancer - should sticker it up).
also two green p-platers in r31's going up the freeway. very impressed if you're on here guys, sticking to the limit.
words fail me.
thats aids, i have seen a worse R33 though, i always try to figure what these epic retards are thinking
When they see my fresh OEM, do they want to also stick the cheapest ugliest accessories on it to make it aids. Or do they think i wish my car look half decent as that, probally the other option.
Edited by starwarz
Unfortunately it was an R31 I saw driving like a dick. Kurrajong Ave and Carlisle at 1pm. White S3 with 17's and a cannon from 5 cars back, into the left lane to run a red and turn right from the left lane. Friggin moron. No wonder we are labelled as hoons. Go buy an excel.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
