REAP3R @ Darling Quarter Parking. Lost for words.
1064768_10201471313169172_1247709468_o.j
Thanks :) It's slowly getting there
^^^ That is pure porn. Didn't it have white rims before?
Yeah had white te37's. I've still got them right now but the tyres are shot
Spotted a white R32 GTR and a silver R33 GTS-t heading south through Warrawong today around lunch time.
The R33 had an SAU sticker on the back windscreen.
Looks like you created your account to advertise the car, coincidence aye
mxzoom
Member Since 13 Jul 2013
Offline Last Active Jul 13 2013 08:04 AM
then you posted the same ad here:
http://www.skylinesaustralia.com/forums/topic/417696-the-edward-lee-hakosuka/page-2#entry6925414
good forum manners.
