Had a chat with Darksky34 at the lights on Balaclava Rd and Epping Rd tonight :action-smiley-069:
Hey Adam hope work wasn't too bad! :action-smiley-069: oh and by the way do you know your two inner tail lights are only half lit up?
Work was painfully dead, bored out of my mind lol
No I didnt know that, i'll need to check those out. Cheers
MR 34 YO
yellow R34 Sunnyholt road. I didnt see him until pulled up at lights. but it looked like he was trying to catch me, almost entered the set of lights when it was red. then took off like a clown.
Why the f*k do you have a VTEC sticker on your back window??
MR 34 YO
Had to read that twice lol
And I had to agree with that question… what the fark!!!
  • Like 1
Followed a white R35 through Glenwood last night between 7:30 and 8pm then a few minutes later passed a white R34 GTR, didnt get the plates but I think it was Brett (REAP3R)
Wouldn't have been me last night I was out and about at that time around there but I was in my s14 instead haha
I had a black R34 GTt parked in my street earlier in Toonie, almost directly across the road from my house. It had a kit on it and black multi-spoke wheels, not sure who owns it and didn't get a chance to check it out.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
