Spotted that same black R31 again this evening around 6.40pm on Station Road in Seven Hills.
I spotted this car again yesterday driving along Station Road in Toongabbie while we were sitting at the AGM, and also spotted a white R32 GTR heading the other way about 10mins later.
Anyone own a gunmetal grey r32 around colyton, st Mary's ect ??
I live in colyton and I raced one a while back I'm my gunmetal grey 32 wanted to know what your running
might of been me troyaustinperry did it have black rims?
Keep your racing exploits OFF the streets and also OFF these forums. We've spent over a decade building a positive reputation for SAU, and don't want it ruined by thoughtless driving and equally thoughtless bragging about it.
If you're going to be doing ANY racing, keep it to the track or go and buy a game console...
  • Like 1
I wasn't the one driving but I understand,
and me an the other guy were not talking about racing I saw his car today about an hour ago
possibly me, coupe, stock rims
yep, thats right i think!
very f*cking shiny BSB R34 GTR, with silver rims spotted waiting to turn left onto mona vale road, I went right past you :rolleyes:
also white 33 gtst on pac highway turramurra section saturday night 1am?
deongster, i live round hornsby too, haven't seen you round!
Cool!! Where - we should arrange a meet up and go for a drive...
wtf ? clearly i was talking about him spotting me not racing
anyway spotted a maroon 32 gtst in st clair today with chromies and also a white 34 sedan on the highway in blaxland around 3pm
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
