Ok here is a question for you fellas that track your 300kw Skylines.
I've been changing the oil after every track day. My GTR makes about 290 kw and has oil catch can, oil cooler, bigger radiator and runs 14-18 psi lo/hi boost depending on the type of track I'm driving.
After about 10 minutes of track time my oil temp is 120 where I do a cool down and come in.
Since the oil temp is so high and on boost for so long I've always felt it is a good idea to change the oil right after coming home from a track day. Always been the first thing I do.
So my question - do you fellas do that too? It is getting a bit expensive cause I only use Motul 300v or Mobile1 Full Syn - so about $100 for an oil change. This on top of track fees, brakes, petrol and tyres. If this is the cost then I'd rather spend $100 preventing oil related engine failure than $$$ for a rebuild. But just want to know how you folks go?
I know a lot of other guys just do normal 5k and don't change their oil after every track day.
https://www.sau.com.au/forums/topic/295705-replace-oil-after-every-track-day/
I change oil every track day, but i do it the other way around. I change the oil before every track day. That way i know i have anice fresh sump and filter before every track day and oil that is in decent enough condition for pottering around on the streets, which lets face it, you can barely gas secon gear on the street so hardly stressful for the engine or the oil you are running
I change my oil every 10 minutes...about how long my engine runs at a meet. :banana:
With around 20K in engine parts invested (my labour is free as i build them myself) a $250 oil change ($25 a litre plus filter) is cheap insurance. I use Motul 300V 'Le Mans' 20W60 and built the engine to run this oil weight.
If it picked up a bearing and or threw a rod and i didn't do this id be always thinking whether if i had done the oil if it would have happened.
Edited by DiRTgarage
I also change my oil before every track day, I dont want to spin a bearing like many others have. I rarely drive my car on the street so i'm not worried about having track day oil in it.
Hmmm, seems to make sense doing it before but means I'm going to go through twice as much oil changing before and after. Maybe I should keep the "street" oil and put that back in after a race day but only run on the race oil for just that track day.
Another expense of having a track/daily driven car. Oh well, need to take care of the beast.
Dont worry about after. Seriosly, if you have done a track day on a sump of oil then i dont see a problem with running it for 4,500-5,000kms. Temp and contaminants are what hurt oil and i cant see you getting too much f either sitting in traffic or going for a drive on the street.
If you run standard or extended sump definatley change before every track day. I personally change my oil every 2-3 track days as I run a dry sump set up with water to oil cooler set up in the radiator end tank so i run around 12-15lt of oil in total inc lines and cooler and the oil temp never sees over 110 deg. Heat is what kills oil so if you can keep the heat down that will go a long way to keeping your oil healthy.
We used to do the oil change just before every track day when i was running the Royal Purple 10w40. When we changed to the RP41 racing oil, we were able to start using the oil for 2 track days as long as I don't do a lot of street k's between them (1000 - 1500). The oil is still seeing < 2500km's total and when we send it away to be tested all results are A-OK.
We did a test where we changed the oil, did about 200k's street, then a track day, (so, <500ks total) sent the oil away to be tested. Drove the car for 1200k's street, did another track day, another few hundred k's on the street, and sent away another oil test. The only difference between the 2 samples was a tiny bit more fuel dilution (about half a percent up from 2.5 -> 3).
Im new to the game but I change it before the track day, Mines a quasi daily as it only comes out if its raining or if I go for a cruise with my daughter and such.
Or if its cold
Or if it hot
Or I have the need, the need for speed (sorry).
I figure it is the combination of heat and lots of boost that might degrade my oil. Basically 110-120 every session for 5-6 sessions over 120k's and a fair bit of boost. I thought that the boost will create bigger compression and therefore more blowby past the rings into the block - e.g. more contaminents. Also I use a return style catch can and get a fair bit of oil/air mix com'n out of the breathers then draining back in.
All good advice here folks I will probably switch to doing the oil change before the track day.
HAHA...I'm in the same boat, I pretty much do the same.
but seriously....change it before the track day, and after if the oil got hot. otherwise like roy said run it for ages on the street.
mine is track only so I change it every 3-4 days, which is normally 2-3 race meets.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
