RIP Gary Tierney (driver) and David Carra (Nav) hit a tree this afternoon during the classic adelaide rally. Kel knew the guys and I guess a few others on here would too
http://www.cams.com.au/Media/News/2009/Sta...20Adelaide.aspx
CAMS has received confirmation that the driver and co-driver of a car competing in the Classic Adelaide rally have been killed in a crash this afternoon.
The crash happened around 3.30 pm on the 7.24 kilometre Special Stage 6, called Kersbrook Reverse, on Norsworthy Road, Forreston.
An emergency medical vehicle stationed at the start of the stage attended the crash.
The stage was stopped immediately and following cars diverted to the next stage.
The South Australia Police Major Crash Unit is attending the scene and the road will remain closed until further notice.
CAMS as the national sporting authority will conduct a full incident investigation in partnership with South Australian Police and event organisers, and have deployed experts to assist in the investigation. CAMS will also offer welfare and counselling support to the families, friends and Classic Adelaide participants
CAMS President Andrew Papadopoulos extended his deepest condolences.
"CAMS is extremely saddened by the incident and the loss of two of its valued members. Our thoughts and sympathy go out to their family and friends in this difficult time.
"We also acknowledge the efforts of the volunteer officials who attended the scene and managed the event under sensitive circumstances."
http://www.news.com.au/adelaidenow/story/0...5006301,00.html
http://aussieexotics.com/2009/11/19/classi...double-fatality
https://www.sau.com.au/forums/topic/296958-fatal-crash-at-classic-adelaide/
Yes, families always try to prepare for this, but never expect it to actually happen. Heart goes out now to the families now in grief and...
God Bless!
Christmas will never be the same...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
