Spotted a dark blue series 1, white series 1, silver series 2 & a black R32 GTST. (Dont know where cos I am unfamiliar with canberra??)
Heading back to the coast and spotted a gun metal series 1 when going through bungendore.
Man, I never get spotted when Im in canberra :(
https://www.sau.com.au/forums/topic/30059-spotted/page/195/#findComment-1524495
I saw a white Stage A at Quickfit today, had a SAU sticker and I think I saw them when a few of you guys met at that meet in Woden awhile back.
Are you sure? As far as I know the only white Stagea in Canberra with the SAU sticker is mine, and it is at Discount Tyre Service Belconnen.
https://www.sau.com.au/forums/topic/30059-spotted/page/195/#findComment-1526411
Heh sorry yeh Discount Tyres I mean't!
Looks very nice by the way.
That's o'kay, and thanks for the compliment. Unfortunately you saw it at a bad time - 4 weeks of dirt and grime and no front spoiler. Maybe back together and cleaner next time you are around.
https://www.sau.com.au/forums/topic/30059-spotted/page/195/#findComment-1527399
Spotted that R32 that looks very similar to Richards, i gace him a big wave and a smile as we rolled past each other (woden carpark) and he gave me a filthy look.....gee i wish i could be so cool that i could snub other skyline drivers *clicks heels together and says "I wish i was that cool i wish i was that cool i wish i was that cool* <_<
https://www.sau.com.au/forums/topic/30059-spotted/page/195/#findComment-1528561
people like that suck especially if he was only driving an r32 gtr if it was a 34 gtr vspec 2 or something i could understand but no offence 32 gtr's are not the most expencive cars out their any joe blow could afford one ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/195/#findComment-1528672
people like that suck especially if he was only driving an r32 gtr if it was a 34 gtr vspec 2 or something i could understand but no offence 32 gtr's are not the most expencive cars out their any joe blow could afford one :)
Still more expensive than that so called "sports car" whale blubber you own ;)
Sorry had to reply to a cheap shot with a cheap shot ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/195/#findComment-1528729
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
