Saw a Silver series II R33 GTS-T just after the roundabout outside the southo Woden. He (or she) was turning right into the canberra college road.
I'll say it now, there is nothing sexier than skyline lights lit up in the mid afternoon, when the sun is just setting. better then the car is a clean silver. hmmmm
i really can't wait to get a 'line, another 3 years atleast :S
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-766502
a white 33 went past me on belco way just past caswell dr at about 4:45, then as i was turning into haydon dr i saw a nice red 31 with a fmic across the way.
Whoa!!! might finally have been spotted (white R33). This is about the time I was heading home yesterday arv - though don't remember seeing any 'lines near Caswell / Belco Way... I was have a little bit of fun with a blue SS at the time though :):rofl:
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-769001
Whoa!!! might finally have been spotted (white R33). This is about the time I was heading home yesterday arv - though don't remember seeing any 'lines near Caswell / Belco Way... I was have a little bit of fun with a blue SS at the time though :D  :D
i was in front of you then i went into the turning lane. my car doesn't look like a skyline at the moment, more a dustball on wheels.
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-771966
G'day Weetbix,
That would've been a mate James.  I don't think he parks there anymore...
J
Damn, it was good to see a decent car in the carpark for a change, way too many riced up lancers that park there.
You wouldnt happen to know who parks a Silver R33 GTS-T Ser2 there aswell would you??
Cheers
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-775247
Cheers
Naa, not sure who owns the series 2.. There's sooo many skyline owners in Canberra that don't know about SAU :D
J
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-775553
i spotted a very nice greeny colour S2 R33 GTS-Tone of the best looking ones i have ever seen in person... the colour is not my favourite dont get me wrong their but in terms of an overall package it looks sweet body is still stock as eg S2 front bar and spoiler etc but it has a nice big ass FMIC in the front bar OMG my pants :D anyways if the guys who owns it on here wants to be nice and let me have a look up close i would appreciate it as i am looking for a S2 and yours would be a good to have a look over... not to buy though :)
https://www.sau.com.au/forums/topic/30059-spotted/page/17/#findComment-775647
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
