about 2 months ago i decided to get the turbo removed from my rb25det, due to p plate laws.. after getting this done i discovered the car does not have anywhere near as much power (sorry all the people that advised me against this i should of listened and you were right), in fact the compression is so low that my girlfriends barina has more up and go, so about 2 weeks ago i decided its time to stop embarrasing myself and put the turbo back in. i bolted the turbo in no problems at all, took me bout 20 mins i thought it would be easy, but i failed to take into consideration 2 copper pipes coming out of the turbo its self and a thicker (screw on) pipe, im not sure where the 2 copper pipes go i cant find anywhere around the turbo area where they would connect to, also they look exactly the same and (apparently) they do different things (one for water one for oil) so i wouldnt want to get this wrong and do some permanent damage to something. i found the spot where the thicker pipe screws onto but i could not locate anywhere to attach the skinny bendable copper pipes around the area where the turbo sits, i do have car ramps if its easier to get to from underneith.. surley someone on this forum would of done this themselves or know of someone who has done this before, would really appreciate a little help.. thanks..
this is what is in place of the turbo at the moment
in the photos below the RED circles are the copper pipes that im talking about, where i dont know the location of..
the GREEN circles are another thing, in the first photo im unsure where that yellow rubber tube goes as there is no location that i can see around the area of the turbo where it would plug onto, in the second photo theres also another cut off yellow rubber tube that has been cut off and had a screw put in it to prevent flow behind the block near the clutch fluid bottle, i dont know what this goes to either, if anyone can help thanks very much..
https://www.sau.com.au/forums/topic/300900-putting-a-turbo-back-in/
  • Replies 118
Perhaps you should take it to whoever it was that removed it, and get them to re install the turbo.
The big one at the bottom is the oil drain, the one on the opposite side of the housing to it, is the oil inlet.
The remaining pipe will be one of two water lines, but there should be two of them, one inlet and one out let.
The hose in the green circle is a boost line that activates the wastegate actuator. I'd say it should be connected to the one by the clutch reservoir that's been sealed off with a screw.
both of those copper pipes attach onto the block, the oil line (the one with the curl in it) sits towards the middle of the motor - the water pipe shown sits towards the rear of the motor (when you attach the bracket for this, it should line up to its location). there is another water line that wraps around from the other side of the motor.
here are pics ive got of mine, they arent the best but i hope it helps:
post-13452-1261362245_thumb.jpg post-13452-1261362263_thumb.jpg post-13452-1261362280_thumb.jpg
One near the clutch fluid is the nipple that should run to the factory boost sensor, really no need for that one to have been disconnected.
The yellow hose running off the wastegate will need to go to the factory boost solenoid which is behind the intake filter box. From memory the solenoid isn't a simple in/out configuration and had a t piece thrown in, just go on ebay and get a $30 turbotech boost controller instead.
And yes you'll probably need to drain oil and coolant before removing any blocking screws from the block.
Edited by nicr4wks
Unless that nipple is running the wastegate and the solenoid has been by-passed for some reason.
Wastegate sensor coming off the plenum after the intake throttle on the stock setup would be a little unusual, but then again wonders never cease  :)
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
