Hi all!
The forum has been lacking a DIY for putting your 4WD stag into RWD mode.
Firstly theirs a number of reasons you might want to:
  • 2wd dyno runs
  • Saving coin on the tuner pulling it out
  • Making yourself feel better due to less power loss from awd system
  • Skids
  • Burning up tyres before installing new ones
  • Any other stupid reasons you can think off......
The reason I'm pulling it is we've got a dyno day tomorrow and only mods since last power run on a 2wd dyno was shift kit and a 3' highflow cat (used to have gutted 2.5')... So im really trying to work out if the kits done anything power wise (yes I will report after the day)
It takes roughly 45 minutes, perhaps allow an hour for first timers
Tools required:
  • 4 Jack Stands
  • 13mm Ring Spanner
  • Trolley Jack
  • 12mm socket on ratchet and whatever adaptors you need for your setup
  • King G Overals :P (for keeping clean while rolling around on dirty garage floor)
Method:
1. Start by jacking up your car get it so all 4 wheels are off the ground by 3 or so inches
2. ENSURE you give the car a good shaking once its up on stands to ensure its nice and stable cos your going to be working under it!
3. Get under and locate your front drive shaft It comes out of the transfer case and has four bolts that go into the front diff
4. Go inside car and release park brake and put it in N
5. Jump back underneath and watch the shaft and spin one of the front wheels to spin the shaft to where its nice and easy to get at each bolt, you need to move the shaft for each bolt. I do them in this position
6. Take your socket and 12mm and put it on the bolt head (side of bolt towards rear of car) THE BOLTS AND NUTS ARE NOT REALLY HARD AND ROUND EASILY SO BE CAREFUL!
7. Try and give it a few spins to get it all moving you may be lucky and it may crack and you dont even need to use the 13mm to hold the nut still to undo them
8. Once you have all four bolts out pull the front of the shaft down and then pull and jiggle it forward. The rear is just a spline set-up thats all sealed so it will come out with a bit of pulling.
9. Drop the car, do a lap around the block with a bit of a heavy foot where you shouldn't (aka out of a corner) and you will soon be able to tell its in RWD. No fuses need to be pulled. You will not get any fault lights or anything. This is the only SAFE way to run in RWD to avoid frying clutch packs ect...
Installation is simply the reverse. Dont need to do the shaft nuts up super super tight. Again THE BOLTS AND NUTS ARE NOT REALLY HARD AND ROUND EASILY SO BE CAREFUL!
Hope this helps someone.
Cheers,
Chris
  • Like 1
  • Thanks 1
https://www.sau.com.au/forums/topic/304189-diy-4wd-to-rwd/
You need to pull the 4wd fuse in the fusebox next to the battery.
"NEED" I think is the wrong word.. I guess you could but Ive had it out before and spoken to tuners and its not necessary. Ohhh and also a mechanic that had his shaft out on his OWN stagea for about 6months with no fuse removal and NO issues
https://www.sau.com.au/forums/topic/304189-diy-4wd-to-rwd/#findComment-5038228
Great howto thanks Chris! Now I have a better idea about what's involved and it looks reasonably straight-forward... as usual, the hardest part is getting the damn car far enough off the ground safely!
Whenever the mech' removes mine he always removes the (big, 30A) fuse. It's not hard - takes 5 seconds or so and has at least these advantages that I can think of:
- saves wear on the ATTESA pump by not running it all the time
- lets the system know that it's in RWD mode (and the driver by illuminating the 4wd warning light)
- stops that infernal clicking! (the dreaded ATTESA relay)
...so why not do it and take advantage of the benefits or however SK puts it... just my thoughts :P
Edited by DaveB
https://www.sau.com.au/forums/topic/304189-diy-4wd-to-rwd/#findComment-5038334
Pulling the fuse is not enough on the Stagea you have to remove the front drivshaft. The Attessa is different from that on the R32 where pulling the fuse was all you had to do.
ah k i use to have a 32gtr wish it was easy as that
https://www.sau.com.au/forums/topic/304189-diy-4wd-to-rwd/#findComment-5038861
Ok for those wondering the shift kit and cat seemed to up the rwkw by 25. This is also with a tiny bit less boost. very pleased awesome day on the dyno thanks rodders!
no worries chris,had a few sms/pm's of thanks and im glad everyone had a good day and enjoyed it. i may organise another in due time
will catch up with you soon buddy!
https://www.sau.com.au/forums/topic/304189-diy-4wd-to-rwd/#findComment-5062629
  • 2 years later...
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
