Hey Guys,
Been thinking, and throwing some calculations around.
Im thinking of maybe building a high comp Rb30det using 11.5cc dome rb25 forged pistons and using a 1.0mm head gasket.
But there is a 0.7mm difference between comp heighs so the 25 pistons should sit .7 lower in the bores of an rb30.
By my calculations it would have a comp ratio of 9.2:1 so its not that bad comp wise as the 11.5cc dome gives 8.5:1 in a rb25det.
Any ideas if this would work or not...I think it would be a good thing for E85/race gas.
https://www.sau.com.au/forums/topic/305187-e85-rb30det-high-comp/
Good to hear, When I started writing this post id forgotten to adjust the comp height so it would have been about 9.8:1, which as you say isnt all that much by todays standards.
I know you can buy 9:1 rb30det slugs off the shelf but every little bit helps, as it makes the cars much more responsive to timing changes, my 8.5:1 comp rb25 was a bitch to tune compared the the 9:1 version in the car now.
So with a Belly full of E85 and say 9.5:1 comp (after the block and head are machined a bit) should be hugely responsive.
Now all I need to do is find just 2 ACL rb25 forgies and im set :(
If I was doing a twin cam RB30 turbo engine 9.0 would be absolute minimum I'd run and preferably the as mentioned 9.5 to 1 .
The extra 500cc or + 20% should be good for in theory 20% more torque and most people say you get more out of each pound of boost with the higher CR .
It possibly means that you may not be able to run real high boost numbers but IMO airflow is what makes the power anyway not a boost gauge number .
Some may not agree but I think the idea of running E85 permanently is a bit premature at this stage , so many water and corrosion problems there may not be long term answers to just yet .
Short term I'd like to see E10 or E15 that was based on 90% 98 ULP at the pump .
Over 9 and under 10 CR for today's turbo road engines , IMO cheers A .
The water absorbison issue doesnt really worry me as it would be for a track car, so the oil would be dropped after each rae meeting,
Being that I'm a poor bugger atm my dirty 30 will have 8.2:1 comp using cast pistons and pump gas, so I need somthing that is det resistant and the low comp gives me that security i need, so that I dont ping the engine to bits if the intake air temp skyrockets from being tucked in behind another car for 4 or 5 laps.
But the high comp E85 engine will come :)
So exactly what spec are you running - 8.2, 8.5, or 9.0?
Not sure why a 0.5 change in CR would make the thing any more/less difficult to tune. Run to your target AFR, and develop an ignition map that doesn't allow the engine to knock. The lower static CR should allow for greater knock resistance at a given boost pressure, maybe at a cost of overall engine efficiency/output.
Also good tuning would/should provide suitable correction for changes in IAT. If you were in someone's draft for 4-5 laps everything would be hot, especially coolant temps?
the rb25 thats in the car now has 9:1, the previous 25 to that had 8.5:1
it just felt that small timing changes made more of a difference in the way the motor responds in the 9:1 comp motor.
Ill be running the 8.2:1 comp rb30det rather rich and retarded, capping power in the mid 200s atw, so it wont be taking full advantaage of the 500cc extra capacity, but i will mean the overall level of tune will be less stressful compared to a 250rwkw rb25 and run cooler, needing less revs etc.
As no one else seems to be aware of it. ARIAS make off the shelf highish comp forged pistons for the 25/30.
These are the ones i have in my engine.
Suit RB26/30, 25/30
p/n= AP332104
10.6cc dome top
21mm pin
1.280" compression height
Only stocked in 0.20 thou oversize (86.5mm).
COMPRESSION RATIO 9.2-9.4
They also make these with even higher compression
Suit RB26/30, 25/30
p/n= AP332105
13cc dome top
21mm pin
COMPRESSION RATIO 9.5-9.8
No need to mess about with RB25 pistons and what not.
Sounds like the tune mine has... LOL
Fouls plugs if you let it idle for 20 - 30 minutes... :)
Suit RB26/30, 25/30
p/n= AP332104
10.6cc dome top
21mm pin
Suit RB26/30, 25/30
p/n= AP332105
13cc dome top
21mm pin
That is very handy to know Thanks mate :)
if they are only stocked in +20 then i may just leave the standard pistons in the 30 for now if they are in good nick, rather than bore it out now
lots of euro turbo petrols are running 10.5:1 to 11:1 CR's these days.
fuel quality and tuning has come a long way in the last 10 or so years
There's a big difference between what can be done with direct petrol injection setups and the port injection setup we have with the RB. Even so, those factory setups aren't running much if any further than 10:1.
My mate has 9.5:1 in his 25/30. E85 and 700rwhp.
The fuel is the secret ingredient there - looking through competition history books shows what has been achieved with high quality blends and rocket fuels. General availability puts a dampener on my enthusiasm for E85.
Considering what the likely pressure ratio (say 12psi) is required to hit a streetable 350rwhp, I agree that perhaps up to 9.5:1 would strike a very good balance for output and fuel efficiency. I don't think I'd like its chances of surviving a hard day at the track though, unless it was running some sort of special fuel.
Suit RB26/30, 25/30
p/n= AP332104
10.6cc dome top
21mm pin
Be a bit interesting to see/hear more on the results of this combination.
Fouls plugs if you let it idle for 20 - 30 minutes... :cool:
Running a tune very rich (say 11.2:1 AFR) at high load does not mean it has to be rich at idle also. Time for a proper tune?
Keeping on-thread, and checking out zebra's build thread, I'll differentiate between the intended uses.
For an occasional track machine it would be hard to deny the benefits of E85, and what Dave's mate achieved should be repeatable. The number of hours use it would realistically see during a year means E85 and >9.0:1 CR would bear serious thought. Good tuning would determine how well it lives.
Keep us posted with progress.
E85 is amazing stuff.
One of the guys at work is playing around with a SR20DET on the engine dyno. Is was a completely standard engine, it made an extra 40hp just by switching from 98 to e85, same boost, 40% more fuel, 15 degrees more timing, where it was pinging a little on the 98, not a hint of a ping on e85.
The rest of the work has been done with a different turbo and 36mm restrictor. He needs 10.5:1 so he can run it to the knock limit again in the higher end where it will be raced. Has 26psi of boost at 4000rpm dropping off from there with the restrictor.
I'm putting together a RB30DETT for my r32 and i will be building the engine for e85, 10.5:1. The fuel system isn't that difficult to make survive e85. Rules are simple, no bare aluminium, anodised is fine. Most bosch fuel pumps are fine, they just say the life of the pump is halved. Steel lines/ rails are ok but the water e85 soaks up can rust them. Zink phosphate coating (like on factory fuel rails) will eventually fall off. Stainless lines are the go. Compatible rubber hoses are available. Steel tank might rust out eventually, meh!
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
