So, more shit ordered for Brad to keep going on this for me...
Starter motor should arrive by Friday at my place for it.
Also need to give a big thanks to Chris from Craved Coatings, many moons ago I sent him a heap of crap and went "Do stuff with it yeah?", I did tell him that I had no rush for it, as it was going to be a long project, and I emphasised this (When you actaully want stuff quickly he turns it around quickly!) but I got my gear back, and it looks SUPERB!
I'll get some photos up of his stuff soon.
I've had Chris do a few bits and pieces now, and his work is ALWAYS superb, at good prices! Seriously, send him your shiznit for powder coating!
So... I told you all Craved returned some parts to me... He did an excellent job...
I've also got the new ECU in... Just waiting on the loom so it can be wired up.
I've also been playing with the headlights and trying to clean them up... Might have to send them away to be profesionally done though... Yay... More money... LOL
I also bought the starter motor that was required so Brad can start modding the steering rack...
I think he's lost his camera too :P
We did find out though, that custom extractors are the ONLY way to go... Yay... More money... LOL
From what Brad has told me, and others have seen as well, the Ls1 and T56 are in and mounted. Last I heard te mounts haven't been 100% welded as Brad was waiting on the starter motor to make sure he only had to mod the rack and not move the motor further.
Wirin loom should turn up to him in 2 weeks time and just need plugs put on it.
Once it's mounted I understand we'll then be waiting on the front half of the tail shaft to be made. We spoke and decided on a 2piece shaft.
So, I gave myself a birthday present of a day off work, and decided to head up to take some snaps so Brad didn't need to worry with photos.
From under neath
Holden thought of the R33 when they made this sump... It fits perfectly...
Supposedly a cat lives here...
I'm going to need to change this
This will cause issues...
See... They do fit...
Just...
Although, it does sit nice and low...
At least I can get to the gearbox bolts easily...
Because of how well the sump fitted the cross member, it's staying where it is, as you can see, it could be shoved back a bit, but that sump is such a good fit!
The shifter works out in nearly the standard location, slightly rearward, but because of the height of the box, the trans tunnel will need a slight mod around the shifter hole to allow the box to sit up all the way.
The back of the box still needs to go between 1 to 2 inches higher when it gets bolted up properly, so the motor will tilt slightly further forward. Even more clearance... :D
As to the rack, it actually needs to be moved to the drivers side a fair bit to make it fit. It's majorly in the way... A bit more obvious in person.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
