  • Replies 54
Posted Images
just added sau to the cacti instance at work and set it to graph http and tcp response times.... i'll send you some results tomorrow if you like.
***scratch that****
looks like i have proxy issues and cant get cacti to reach it... might take me a day to fix it.
yeah as far as I can tell, it takes a long time to respond between 10am and 12am, the data eventually comes through, so I'm guessing its a database/software issue than a connectivity issue.
good to see its not just me, i was beginning to lose my shite @ our server setup... thinking it was at fault :(
It really is a random thing, it went all slow for me about 5mins ago and its late.
i get it every time i load SAU. page will be blank and say loading for about 30sec when it use to load straight away. surfing through threads is alright. lil laggy but not too bad just the start up thats bad for me
I'm surprised no one has mentioned this...
it seems to happen around 4:30 on the dot... for me, it happens at other times too, but I am using a proxy to get here as work has blocked it but won't admit it... so it could be a number of things. But every afternoon, around 4:30, I leave SAU cause it doesn't respong for some time...
Christian, if you don't mind me asking, what kind of costs do you incur hosting this website? And what kind of traffic does it normally see? A PM is fine if you like.
I recommend all the people complaining about the lag to please donate money to SAU. Australian servers cost a lot more than american servers and thats the only solution to get everyone quick page loads.
Open up your wallets people! Barely anyone who posted in here have a 'donated' tag under their avatar.
http://www.skylinesaustralia.com/forums/in...&CODE=index
ok post 2.0 (first one got lost after i hit the add reply button and the site crashed)
it took me 3 mins to get into this thread last time, and took me 5 mins this time. the site keeps coming up with a notice saying that the connection was reset. it hasn't been getting really bad. i've had it happening all day at work and it's even worse tonight. it is completely random. i opened up a few windows today (about 6 i think) and only 1 of them loaded, the rest crashed, and then the one that did open crashed when i tried to submit a post. yesterday the site only had a few downtimes, but today i'd say i've had it crash 4 or 5 times an hour. sometimes (like at the moment) it will crash, then come good, then crash again within 20 seconds of coming good again. over the last few days it was just hanging and taking ages to load but today it has been coming up with the error i said before about the connection being reset. i did have 1 UPS error or whetever it's called pop up, and i've also had some pages load with a shortened web address at the top of the page in the title box thingy. so at the moment this page has "site hard to load? - skylines australia - mozilla firefox" but a few times it's had the web address in there. also sometimes tonight when it has crashed and i've hit refresh it's come up with a box asking me if i want to save a file or open it and asking what program to open it with. the file usually says the thread name and has the file type .info (i think).
ok, lets try this again
*crosses fingers and hits add reply after copying this reply incase i need to post it again
Donations are disabled at present, have been since last year due to other issues we were having with the entire system :P
Will be fixed shortly, it's my next "to-do" item!
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
