lol ill still beat u :)
someone organise a east meet for the 15th or 16th :)
eh, so be it. when im off my P's and buy an R32 GTR we shall see! :P
tho that thing would be so f**kin old!
so are the l28's any good?
there's not much performance gain from L24 to L28, unless you really work the engine. I mean ideally if you wanna keep the old school donk you'd wanna bore it out to a 3.1L and fit some mikuni carbs to it or someshit.
but here's reality... you nor anyone on this side of the planet will not be fucked doing all that. so just keep the shitty engine that's in it till it carks it from a cracked headgasket or soemthing and then throw it out, find another engine and repeat the process till you can afford a better car.
here are your order of priorities:
1. get car in registerable condition
2. register car
3. make sure it drives OK
4. modify it or think of changing engines
now stop being a retarded dickbag with grand dreams when all you've got atm is a shitty rusted out car that's not even on the road.
Thats the time frame I'm there lol. Hopefully it's the last interstate work I have to do for a while.
Been to Perth, Launceston, Brisbane and Mackay in the past 5 months. Add another Brisbane to the list as of next week.
my flight was to mackay and then a 5 hour trip up north just off cairns. The humidity was a killer up there. More water than oxygen. 24/7 Aircon in the car and at the house lol
Funny to see people having water hoses running 24/7 watering a patch of dirt. No water restrictions up there.
A damn!
That's awesome!
LOL! Kris loves China Bar.
I would have came but I only got on SAU while you were all heading out, + I needed sleep after NYE.
Kris doesnt love China Bar as much as I do. I wasn't going out for Rock Kung at that hour...pfft.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
