I love my phone plan, $150 p/month = unlimited calls + txt.. had a to many bills over my cap :)
I love mine more 99+ 14.95 Internet package = unlimited calls and text + 1500mb Internet. It's good when you can dowload torrents on Your iPhone :D
hey guys i need some help. no one seems to have a gear box atm :D i tried osaka imports and he doesnt have any and wanted 1k to get me one. a 20 box for 1k ahh no thnx. so can anyone suggest any other import wreckers i might try? i looked in the thread for workshops but half of those places dont exsist anymore :) any help much appreciated
FFFUUUUUUUUCKKKKKKKINGGGGG HELLLLLLLLLLLLLL
dont you ahte it when you got the cash in hand, and find that one car that you have been looking for. and shit just goes wrong and your forced to delay the purchase of the car?
yeah. i just copped that shit today
what happened? thought your old man was payin for it?
yeah, f**k that. he's already spent 18 years feeding me :)
i wouldnt let him pay for it. just some unrelated things happen. need the money elsewhere :D
note to self: in future when buying a car, always keep some emergency cash on hand
Edited by GTR-boy
worst case you can try these guys http://www.japanesegearbox.com.au/rebuilds.html
Last time i was there, they can supply a full rebuilt rb20 gearbox for $1k
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
