Yeahh boiii
You got a pic of that but she in a bikini.
:huh:
With a kit and a less homo colour I reckon it would be one hell of a car.
Looks nice and clean.
Paint it red or black and change those wheels.
I don't mind the wheels. And don't worry, it'll be black or midnight purple :huh: Or maybe even gunmetal (to be different) or something stupid like orange lol. Will wait til I'm off my P's before I kit it and all that though.
I don't mind the wheels. And don't worry, it'll be black or midnight purple :rolleyes: Or maybe even gunmetal (to be different) or something stupid like orange lol. Will wait til I'm off my P's before I kit it and all that though.
Haha!!
Don't need another Skittle rolling around. (Jokes)
I always liked the factory Red that the MR2's came out in.
Keep it red and it will look hot!
red just makes em look like toy ferrari's. I like em in white, we imported a white MR2 turbo for this kid in reservoir ages ago... was hot as.
kinda like this one:
I like that Shan! Not sure about the Border front bar though.. bit too rice for my liking. I like to keep the sleek lines of the car.
But then again, I didn't like my Bomex bar either.
These cars have inspired me...
I think I can see a common pattern there :rolleyes:
Haha!!
Skittles don't look too bad :thumbsup:
Hmmm... Red...
As Shan said... FERRARI :rofl:
Edited by jezza boii
wait... wat?
is that a veilside kitted MR2? that shit is kryptonite to even Ron Jeremy's hardon.
Nooooooooooooooooooooooo. It's a Sard front bar. They don't make them any more though.
Veilside looks like this...
Actually white does look tuff!
If this was slammed down low with a set of decent wheels, it might just look OK.
Damnit, Veilside is Hit or Miss with their body kits.
I disagree. Veilside is ALWAYS a miss :rolleyes: I've never liked it on any car.
Veilside kitted lambo...
although at that price range of car, they better get it fucking right.
I know, them northside boys give me rock hard greasy boners every single time I see em, kinda awkward being around them with my pants tightening. :rolleyes:
errrr.
okay?
I disagree. Veilside is ALWAYS a miss :rofl: I've never liked it on any car. It looks especially bad on zeds.
The 350Z Version 3 body kit looks nice, with Andrew Evolution Wheels + deep lip.
Hell yeah!
Even though that doesn't look too bad, since when does a freakin lambo need a bodykit?!
Kinda looks stock... Haha!
:thumbsup:
im from the north...
i feel kinda scared now though... :thumbsup:
apexi now do a boomslang patch harness for bnr32/bcnr33/bnr34 and er33/ecr33
this is just an extension but it allows you patch in whatever you like instead of cutting random wires inside the car
http://www.nengun.com/apexi/straight-harness
wish i had of got one of these before i started cutting wires
they werent out ages ago
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
