ye, well I'm not about to go and buy 2 more TE37s just for the sake of offset, though I think I'm going to have a problem when my ATTESSA is working again with having staggered fitment anyway blah
You should be fine!
why not? once you have jap rims, then secondhand jap rims are a freeforall... just sell 'em for the same price as the next set you are buying
if you're using spacers, make sure you get the washers on them to stop them moving around and they won't mess your wheel balance up. if possible get ones with hub bolts, they're "safer" than just slip on's and don't move around at all, but you'd need a 15mm+ spacer for that, which might be too much.
but yeah, nothing beats choosing the right wheels with the right offset.
too much effort haha, yeah I'd never use slip ons, an R33 here had a wheel fall off due to having fark all thread and having the wheel nuts come off LOLZ.
Here's a pic to show fitment as it is currently :
Rear looks decent and could go more low!
your talking about slip on spaces hubcentrics bolt on to ur existing hub and give u 5 new threads so you do not lose any thread and if his wheels fell off with hubcentrics then a retard tightened them.
deff need to sort out the front and slam that tractor. john deere reprezent!
yeah, rear is fine. front needs a little more out... 15mm to 20mm? then roll the lip on the guards and drop it by just under an inch, should leave minimal gap, you don't have to run stretch tyres, shouldn't have scrapage on lock or over bumps... but it'll look tough. probably will get defected for height though cos the bottom lip of the front spoiler will drop under 10cm.
alternatively if you don't give a fuck, then do this:
18x9.5+15 front
18x10+20 rear
near perfect fitment for R32 narrowbodies. maximum wheel width, no fouling on suspension, and with a roll, no scraping.
alternatively if you don't give a f**k, then do this:
18x9.5+15 front
18x10+20 rear
thats AWESOME!
wheel sizes noted :stupid:
is that yours?
lol nah, mine's 6 different colours and runs stock GTR wheels atm... one day I'll get off my arse, fix the ABS system that's causing the front passenger side brake to permanently clamp on, and paint n panel it and throw on some wheels.
or I could sell it as is and drive the camaro when it gets here.
seriously cbf with the skyline atm.
18x9.5+15 front
18x10+20 rear
lol what size tyres are those?
Im running 17x9 +30 with 255/40's and no chance that will tuck under the guards with -0.5deg camber & rolled lip
hehe that does look sex, I like my ride height lol, no scraping on speedhumps or police attention for me! I actually like it that height, no scraping on speedhumps or police attention for me, and if I park too close to teh kerb, there's about 2mm of clearance to the front spoiler lol.
I would have thought that if I get the fronts to stick out further, that I'd have trouble with it fouling on full lock etc ^_~
As it is, the exhaust just clears 10cm, don't really have much fine adjustment re height, the coilovers are only circlip adjustable! More concerned with handling tbqh.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
