Lol, its not really something to envy, with practise anyone can draw/colour as good as anyone else IMO. Plus it's not like I just started out of nowhere :thumbsup: I've been drawing for yearrrsss.
and to top it off;
flush enough for you?
no
32 on the left needs wider wheels up front, but I'm guessing he's running spacers on the back wheels to get "flush", but doesn't run them on the front because it scrubs on the guard which he cbf sorting out properly. Being a GTR driver he probably got the same width and offset front n back, without taking the extra 5 mins to do the math to get a staggered fitment or different offsets on the same widths with the same overall rolling diameter.
32 on the right needs to man up and run wider wheels all around. And roll that guard lip before it shreds his tyres.
Critique this one Shan...
no critiquing necessary... that's good fitment. Coulda gone with a nicer kit, but meh, its a 300zx, only good things on them are the AFM, throttle body, brakes and manual gearbox, so its kinda like polishing a turd when it comes to aesthetics.
That said, it is the outside facing side of a bend, which means he's running almost "krzysiu spec" suspension making it lean on the corner. post up a pic of it standing still and you'll see it needs more low.
QLD guys are usually on point when it comes to fitment and stance.
notice a trend with the cars from the US and europe? focus is on stance, and keep it simple. no big shitty over the top kits and paintjobs.
need some tips for this. i wanna go lower but not sure if there is a point
well decide if you wanna put up with sump bashing, lower control arm collecting, manhole cover/cat's eyes scraping etc, attention from cops and so on, then dump it on its guts. scraping is fixed by relocating cables, flaring fenders and bending inner guards and proper wheel/tyre choice.
stance, function, practicality. pick one.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
