R34 GT-4 + RB26 + turbos + intake + front pipe + flywheel + clutch + wiring loom + ECU + brakes + diffs + exorcist + hub assemblies + brake booster + gearbox + ATESSA controller + dreams + G-sensors + radiator + radiator support + hopes + bumper support + bumper + front guards + rear guards + respray + bonnet + instrument cluster + GTR dash insert + dash mounted gauges + fuel pump + fuel regulator + water pump + oil pump + alternator + starter motor + prayers = 4 door GTR
Fucking just buy a GTR!
:D
:D
yeah exactly. fuck making a 4 door GTR, buy a GTR and tell your two mates to harden the fuck up and sit on the shopping bag tray back seat or catch the bus.
So I saw this in the Stagea Thread...
Guess we will wait for the R33 GTR front...
w..t..f? that's the most retarded looking shit ever. no that GC10 fronted stag was the most retarded shit ever, this is a close second.
looks like someone in thommo had a frontal in a stag and then fixed it using his cousin's skyline parts and shitty fibreglass "widebody" fenders.
:rofl:
what if i wanted to stick a a ford I6 in it..... :down:
GTR-Boy, stop piss farting around, save up your hard earn cash and put it towards a decent car.
lmaoo i already said i want an R33 NA..
and that R32/C34 :) .. wtf
i reckon for your first car just buy any old piece of junk
treat it like ass, dont look after it etc
then when you have appreciation for it and your off the p's
get a nice skyline and off you go
your probably right. but, no.
i love skylines. always have, always will
:rofl:
Not even the Japanese could pull this off this time.
:rofl:
what if i wanted to stick a a ford I6 in it..... :thumbsup:
and that R32/C34 ;) .. wtf
*face palm*
:laugh:
I think he already has a Toyota Hilux to get from A to B.
And for the love of God, love the right one (Skyline).
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
