On the topic of Real Estate agents...
The muppets who manage the property I am renting, recently did an inspection, and claimed the carpet is dirty...when in actual fact it was like that when I moved in (brand new place), yet it's now MY responsibility to clean it. Got photo's and the initial inspection I filled out to prove them wrong, but the tenancy union are a bunch of weak f**ks.
if your talking about your vacating inspection it is mandatory for the tenant to steam clean the carepts upon exit it will be clearly stated in your lease, if your still in the property and not moving out you can tell them to get fkd but keep in mind when you go to leave you will have to do it VCAT wont help you with it and yes the tenants union are useless if you got questions feeel free to pm me or something i did property management in my early days :blush:
Well I'm going to move out anyway, but yeah, aware that we need to steam clean it before we leave. Just a pain in the arse that the place was dirty when I initially moved in, and the fact that I had to wait a couple of months for the correct remote for my split system in the living room. Very unprofessional on their part me thinks.
yehh i hear ya man common problem unfortunately all that you mentioned is up to the landlord and they are the biggest tightarses/lazy mofo's around i found they are harder to deal with then tenants usually but the tenants are the ones who always cop the shite :(
f**kin bummed i missed goodlife.. i thought it was on the 31st -_-
started playing MW2 online on ps3.
damn there are some pretty good people on there. like respawn and bang your dead
add(own) me peeps. sam3075
hmmmmm... ive lost 6 hours of memory.
i remember our cricket team thrashing the shite out of our opponents at the grand final... then i remember going back to the club rooms and having about 4 beers, then shotgunning a beam and cola then waking up on our couch nekkid at 8am this morning....
i also dont seem to have my phone any more... or my oakleys... lol
i do have my sim card though which has me intrigued as to the phones fate
dropped in the loo/river for sure. check under your nails to figure out which.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
