lol that's what my P plate used to look like on my R32 in 2000. 3 years n a cop never said a thing about it.
and the wheels are SSR Vienna Dish... close :(
I see.
A friend of mine just bought an E50 El grand with Fabulous wheels and yeah, they look very similar to SSR Vienna Dish.
He is waiting on TEIN Coil overs from Import Monster and slammit! :)
oh and...
GTS logo I made from way back:
and evolution of the SAU logo I made:
Ah... So that's how you designed it.
Interesting.
is he on the elgrand forum? the aus one... cause someone was on there asking about them as they were going to order them.
we got them on ours with the electronic damper controller and theyre awesome... ive had to raise it up a bit though, especially in the rear because there was no clearance between the rear axle and the bump stops so it was bottoming out on every pot hole and slight bump.
want to get some new wheels for it soon... white with polished lip.
btw - anyone know of anyone getting an RB25 or RB26 tuned in Moorabbin tonight? Cause someone has one on a Dyno somewhere and its getting f**king flogged! Last 2 hours hitting the limiter, doing a run nearly every minute.
Poor car.
yeah why would you buy wheels if you had your car for sale?
+30 9inch with 255/40 tyre. Flush enough for you? Too bad it will completely destroy my front guard haha
The tyre shop put one of my 9inch wheels on the front. Car looked weird with a 225 and a 255 on the back pair lol
*facepalm*
fuck off before I act on my temptation to hit you with a chair.
well i bought the wheels and then as the wheels were being put on i got the call that someone wants to see the car. so far iv been getting tyre kickers so thought meh will just go along with it. he came saw the car then gave the deposit next day. but wheels were not sold with the car and will keep em for the next car.
Environmental vandal.
WHAT WOULD BOB BROWN SAY?!!!oneone
Poor trees never hurt anyone.
woo, 3 trees coming down today, making room for the extension
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
