lol yahoo japan auctions is a joke... last set of wheels was 3 people bidding:
me
streeter
nigel
FFFUUU bloody melbourneians (and ex melbourninans) wanting epic fitment wheels all of a sudden.
check these funky not bad offset and 1k is cheap be good ona 32 if ur 5 studs
http://www.vicimportsclub.com/forums/thread-1597.html
he can suck a dick for 1.5K for shitty old work rezax's. you can't get rid of em in japan.
meh... still spewing i missed out on a set of BIM driftmasters to Nigel for $1300 delivered :ermm: altho they're gon on his sex 180, so can't be too unhappy, it'll see a lot of fender to lip action, like all good driftmasters should.
me
streeter
nigel
lol tell me about it.
I wanted to buy something thru streeter but the highest bidder was streeter for another aussie. So he couldnt bid ontop of himself with my limit lol
Anyone with a PS3... Best and cheapest option for running HD media through the PS3... PS3mediaserver
been running it for a while now... all my 10-14GB mkv files stream through it like theres no tomorrow.
unless your using wireless in which case only the 720p files will work.
just waiting now on my 55" LED to arrive and i'm set for many hours of zoning out... poor josie
when i was playing around with ps3, i had to run a media server prog on the pc to access any vids on the pc etc.
Although when my brother hooked up his Windows 7 pc wirelessly, it appeared on the ps3 menu without any server program O_o
to play anything other then divx you need to run the mediaserver app on your PC... mkv files are the high def rips which it doesnt run.
ps3mediaserver is the best software ive used so far.
other then that you shouldnt have to run an app to share, but like u said with win7 it auto discovers pretty much straight away. You just have to setup the libraries.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
