lol yahoo japan auctions is a joke... last set of wheels was 3 people bidding:
me
streeter
nigel
FFFUUU bloody melbourneians (and ex melbourninans) wanting epic fitment wheels all of a sudden.
check these funky not bad offset and 1k is cheap be good ona 32 if ur 5 studs
http://www.vicimportsclub.com/forums/thread-1597.html
he can suck a dick for 1.5K for shitty old work rezax's. you can't get rid of em in japan.
meh... still spewing i missed out on a set of BIM driftmasters to Nigel for $1300 delivered :ermm: altho they're gon on his sex 180, so can't be too unhappy, it'll see a lot of fender to lip action, like all good driftmasters should.
me
streeter
nigel
lol tell me about it.
I wanted to buy something thru streeter but the highest bidder was streeter for another aussie. So he couldnt bid ontop of himself with my limit lol
Anyone with a PS3... Best and cheapest option for running HD media through the PS3... PS3mediaserver
been running it for a while now... all my 10-14GB mkv files stream through it like theres no tomorrow.
unless your using wireless in which case only the 720p files will work.
just waiting now on my 55" LED to arrive and i'm set for many hours of zoning out... poor josie
when i was playing around with ps3, i had to run a media server prog on the pc to access any vids on the pc etc.
Although when my brother hooked up his Windows 7 pc wirelessly, it appeared on the ps3 menu without any server program O_o
to play anything other then divx you need to run the mediaserver app on your PC... mkv files are the high def rips which it doesnt run.
ps3mediaserver is the best software ive used so far.
other then that you shouldnt have to run an app to share, but like u said with win7 it auto discovers pretty much straight away. You just have to setup the libraries.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
