lol yahoo japan auctions is a joke... last set of wheels was 3 people bidding:
me
streeter
nigel
FFFUUU bloody melbourneians (and ex melbourninans) wanting epic fitment wheels all of a sudden.
check these funky not bad offset and 1k is cheap be good ona 32 if ur 5 studs
http://www.vicimportsclub.com/forums/thread-1597.html
he can suck a dick for 1.5K for shitty old work rezax's. you can't get rid of em in japan.
meh... still spewing i missed out on a set of BIM driftmasters to Nigel for $1300 delivered :ermm: altho they're gon on his sex 180, so can't be too unhappy, it'll see a lot of fender to lip action, like all good driftmasters should.
me
streeter
nigel
lol tell me about it.
I wanted to buy something thru streeter but the highest bidder was streeter for another aussie. So he couldnt bid ontop of himself with my limit lol
Anyone with a PS3... Best and cheapest option for running HD media through the PS3... PS3mediaserver
been running it for a while now... all my 10-14GB mkv files stream through it like theres no tomorrow.
unless your using wireless in which case only the 720p files will work.
just waiting now on my 55" LED to arrive and i'm set for many hours of zoning out... poor josie
when i was playing around with ps3, i had to run a media server prog on the pc to access any vids on the pc etc.
Although when my brother hooked up his Windows 7 pc wirelessly, it appeared on the ps3 menu without any server program O_o
to play anything other then divx you need to run the mediaserver app on your PC... mkv files are the high def rips which it doesnt run.
ps3mediaserver is the best software ive used so far.
other then that you shouldnt have to run an app to share, but like u said with win7 it auto discovers pretty much straight away. You just have to setup the libraries.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
    • Thanks for the details mate , for me I think being a daily driven and happy with a basic tune (630Nm and 310kw) . Seems to be working well I just put on a set of Michelin Pilot Sport 4 should help put the power down. I'm going to start looking a brakes and LSD in the future so I might reach out to you on options to upgrade the brakes. Cheers - Dee
    • I have a HR34 GT... RB20DE My speedo doesn't work! The rest of the gauges seem to work, fuel and RPM. I did not notice if my odometer was going up when driving last.  Any ideas? Speed sensor? Hopefully atleast... Gauge cluster perhaps? Or is that unlikely because the other gauges are working?   Any insight is appreciated. This is a rather new to me car. Lol
