Was tossing up between the cube and the golf for cheap shitty daily that I could give some epic stance.
Cube 12k purchase price with hookups, almost $6k in mods ($2k for airbag suspension, $1.5k wheels, $1k paint, panels and parts, $1k stereo, tint n all the wanky shit).
Golf $5k plus $6k = 11k which is under the purchase price of a cube. Cube is 2003 model, Golf is 2002. meh, still much more modern and reliable than a clunker of a skyline.
scroll down ya lazy kent there 1k
can you get your mate to measure the centre bore for me on those wheels, might try and wrangle em onto the golf with PCD adapters.
actually... FFFFUUU they're 17's. He can really suckadick asking even 1k for 17's.
finished installing the fuel setup on the ke70.... just need to neaten it up and put some padding under the pump to shhhh it a lil
2lt surge tank, lift pump and 044 out of leigh pidwell's 260rwkw SR powered KE....
think it'll handle my n/a 100rwkw? :P
lol funky.. yeh 17s are fine man lets u go more low.. fkn old schoolers
on a gold id be rockin negative offset 15s
post pics of 5k purchase pls
might just get these instead... should come to about $800 delivered at the current bid.
18x8.5 and 18x9.5 both +45 offset. 8.5 +20 offset gives flushness with the body on a golf, so by my calculations, if I add a 25mm hub PCD converter, it should let me clear struts arms etc, and push it out an inch, which I can then tuck in using some guard rolling/flaring and some camber.
lol actually i dunno what it looks like. I just gave money to my mate Roshan that runs Driftline and told him to snap one up that comes up at the shops or customer cars or whatevers... money talks, they are worth at least $9000 but hard to say no to cold hard instant cash.
Fucking NICE!
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
