might bitch out and run 225's on it. I'm running 215's on 9.5" rears on the ceffy, and it handles just fine. With the golf though, I want a near 60 degree sidewall to tuck in under flared out guard lip. Golfs run a factory fender flare, then a lip. Most guys homo out and just leave it as it is and try and tuck shit under it. I wanna make that lip follow the angle of the fender, then make the tyre run parallel to it.
Anyways, got the wheels. Should cost about $1300 landed. I hope. Been ages (almost a year) since I bought a set of wheels, god knows what the price of shipping is these days... and I cbf waiting for a container.
who would've thunk a Subaru Legacy is perfect fitment for a VW Golf...
looks like a spitz of some kind
lol i've got wheels and I don't even know what colour the car is... apparently I've got a choice of two, one is blue and the other is silver. choices... lol I'll probably pick the one that is cleaner.
liking the idea of blue with silver chrome wheels though... probably end up respraying it black with some ghey off centre euro racing stripe.
this is the look i''m after... minus the overdone flat black... and the wierd bits on the front bumper... maybe a smidgen higher so i can kiss the fender with the rim instead of tucking the lot like a dirty minitrucker.
gonna be baller.....
soooooooooooo i've sorted out how to fit the wheels to my ke70.... and keep it slammed (15x8-9)
flare guards 2"
castor wheels forward 1"
xt130 lca's to camber it in around 1.5"
hacksaw the fronts of the guards around 3" forward
195's
the rears need a big flare + some stretch and that's that
also i'm puttting an s series rear end on there which will act like 2 x 10mm spacers
FFFUUU suspension for both the R32 and the Golf is gonna cost me a month's pay. FML.
funky fk that vw looks like shit fitment.
Yeah he's running a 5x100 PCD to 5x114.3 PCD adapter, and even then he's settled for the minitrucker look. The Meister's I got are 5x100 PCD and have maximum allowable offset. If my calculations are right it should poke out an inch so that I can flare the guard to cover it.
Oh - what hours you working this weekend/long w/e funkeh - i comes get PC bits :down:
dunno if I cbf working this weekend... I'll chuck the mobo in the boot of the car, so just tell me when you're free and I'll come see you.
yeh should look the goods what colour is the car?
fucked if I know, I haven't even seen the car yet. All I know is that its an MK4, and its petrol, and that its gonna cost $5000. My mate's handling the buying/sourcing. Needs a VIV, but we do that day in day out, no probs.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
