i naturally assume theyre Sri Lankan or Indian, as 9 out of 10 of the supras i see these days are driven by them and usually have roof wings, many bonnet scoops which dont have holes cut for them and roof vents with the ugliest chrome 17inch rims youve ever seen.
yeah them...
aaaaah Nico Rosberg... who's he race for?
Mercedes GP, alongside M. Schumacher - The Germans
lol personally I don't care if you've got a 600kw GTR, no fucker is driving my car unless I'm 100% confident in their skills.
This lesson was learnt after some guy who claimed to be a "awesome driver" with a 300kw GTSt rode the clutch on my triple plate ORC rx7 and fucked it.
I don't ask to drive other people's cars, and I don't let others drive my car. My car, my mods, only I've driven it long enough to know every little detail about it. You don't, and I don't trust you to treat it the same way I would. Simple as that.
^^ That's fucked man!
Did he fix it? Pay for it?
Same with me, the only ppl I let drive is my mechanics who I know personally.
Also my panel beater, but they know not to 'drive' it, only when moving in and out of the workshop.
+ I wish not to see my panel beater at all, meaning I don't want to have any panel damages.
If I'm in the car to supervise then generally anyone that owns a manual car is welcome to drive. At any stage I can say GTFO.
The people I don't trust are panel beaters and the like... I've only had bad experiences with them. F*ckers used like $40 of fuel when apparently all they did was "move the car around the workshop"
lol dumb kent... i told him "its a bridge ported T88, its got a triple plate... can you handle it?" and he's like "yeah man I know how to drive manual and I have a powerful car". Crunched the gears when shifting to 2nd, 3rd and 4th cos it kept wheelspinning on him, almost dropped him when he finally pulled over.
yeah actually, the people who drive it are my mechanic/panel beater, and the boys who work at the workshop. Cos they all know how to properly drive cars.
Only people that drove my car were
My brother - when it was stock/mildly modified
My mum - when I was overseas for a few months, 250rwkw
RE Customs/mechanics/suspension guys etc
Justin
The guy that bought it didn't even drive it until he had handed over the cheque and was driving back to Sydney...
Yeah even when selling my cars I never allowed test drives. I'd drive them to show them how the car drives and tell em I'm protective of my cars... they usually understand. I've had one guy get all suspicious so I told him to fuck off. No exceptions.
I echo this.
I would never buy a car that I haven't driven. Some people that know their cars really well can hide some faults with their driving. When I went to look at my car the owner drive first then let me drive it so I could do a few tests.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
