i naturally assume theyre Sri Lankan or Indian, as 9 out of 10 of the supras i see these days are driven by them and usually have roof wings, many bonnet scoops which dont have holes cut for them and roof vents with the ugliest chrome 17inch rims youve ever seen.
yeah them...
aaaaah Nico Rosberg... who's he race for?
Mercedes GP, alongside M. Schumacher - The Germans
lol personally I don't care if you've got a 600kw GTR, no fucker is driving my car unless I'm 100% confident in their skills.
This lesson was learnt after some guy who claimed to be a "awesome driver" with a 300kw GTSt rode the clutch on my triple plate ORC rx7 and fucked it.
I don't ask to drive other people's cars, and I don't let others drive my car. My car, my mods, only I've driven it long enough to know every little detail about it. You don't, and I don't trust you to treat it the same way I would. Simple as that.
^^ That's fucked man!
Did he fix it? Pay for it?
Same with me, the only ppl I let drive is my mechanics who I know personally.
Also my panel beater, but they know not to 'drive' it, only when moving in and out of the workshop.
+ I wish not to see my panel beater at all, meaning I don't want to have any panel damages.
If I'm in the car to supervise then generally anyone that owns a manual car is welcome to drive. At any stage I can say GTFO.
The people I don't trust are panel beaters and the like... I've only had bad experiences with them. F*ckers used like $40 of fuel when apparently all they did was "move the car around the workshop"
lol dumb kent... i told him "its a bridge ported T88, its got a triple plate... can you handle it?" and he's like "yeah man I know how to drive manual and I have a powerful car". Crunched the gears when shifting to 2nd, 3rd and 4th cos it kept wheelspinning on him, almost dropped him when he finally pulled over.
yeah actually, the people who drive it are my mechanic/panel beater, and the boys who work at the workshop. Cos they all know how to properly drive cars.
Only people that drove my car were
My brother - when it was stock/mildly modified
My mum - when I was overseas for a few months, 250rwkw
RE Customs/mechanics/suspension guys etc
Justin
The guy that bought it didn't even drive it until he had handed over the cheque and was driving back to Sydney...
Yeah even when selling my cars I never allowed test drives. I'd drive them to show them how the car drives and tell em I'm protective of my cars... they usually understand. I've had one guy get all suspicious so I told him to fuck off. No exceptions.
I echo this.
I would never buy a car that I haven't driven. Some people that know their cars really well can hide some faults with their driving. When I went to look at my car the owner drive first then let me drive it so I could do a few tests.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
