arent 34 guards bigger then 33?
barely, but that is talking bout gtst vs gtt. r33 gtr guards are bigger than gtt and about on par with r34gtr
yeah gtt guards to 33 gtr guards we are talking bout
they'll look hot, but they won't be flush.
ah fuck it, you'll probably never lower your car to epic stance anyways, so nobody will notice that they're 7mm further in than they should be.
he better be giving away a free reacharound with em at $3700 tho. or at least offer to cup your balls for a solid 5 mins.
haha
that said 19x9.5" +11 > 18x10 +15
more clearance from struts, larger diameter.
If you're not gonna fit them spot on, then at least get the ones that are gonna look nicest. 19" GTC's look way nicer than 18" ones... dunno why, maybe cos they look nicer in larger diameter on 350Z's.
I just re-read your original post, they're both 9.5" wide so you should be fine cos its only the offset that's different. Thought you said 9 and 9.5 for some reason.
ah ok so those 19s from import monster will be completly 100% fine the +11 and +21? cool that means i get a choice ;)
i know that Matts will probably be in better nick thats the only issue but his are expensive
Funky, anything wrong with my fitment? ;)
This is the look ill try and achieve but this is how it looks when im entering my driveway on an angle. So the body has shifted over the wheel.
Should I downgrade to 8inch +30's or try to force fit my 9inch +30's with 255's lol
sick of auto.
if your sick of auto then maybe you should buy my car its not entirely auto, its tiptronic as well, with a shift kit. ;)
so buy it lol, i need it gone to make room for my new and better car.
I'd thought Fujitsubo would sound a lot more quiet..?
fujitsubo make about 4 different types of exhausts, only the Legalis (or Regalis in japlish) is quiet IMHO.
Ah yeah, true that and the quiet ones would be the Oval shape mufflers yeah...
I keep remembering Juliette's exhaust on her R34 GTT and it's pretty much silent.
:blink:
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
