Anyone know of any electrician jobs paying 90k+ based in Melbourne? My current job is really giving me the shits, having to travel interstate at least a couple of weeks a month, when it should be shared around with the other tradesmen. I feel like a f**king puppet at the moment...
Just a few ideas that are going through my head at the moment. Just being overworked to the bone, when I was told that work would be shared around has really given me the irrates. Not to mention the full-blown argument that I had with both my bosses. Probably won't end up leaving, but just weighing up my options.
Might see if I can get into cruisy construction work again :)
sorry to hear juliette
hope its something simple, if there is no grinding, no chucks of cogs etc surely its something simple
on a good note all our plastering is done, finito! rangehood ready to go back in, all roof panels fixed (were sagging) and holes fixed up
tomrorow sanding mission and then undercoat and done wooohooo
Does anyone have any spare 3inch silicon hose bends? Im after a 90degree bend or 45degree bend, just want to borrow and/or buy if it fits!
My airpod sits too high and hits the bonnet, want to put a bend between the AFM and airpod so its sitting inside the vacant space where the airbox was! (or a bend between intake pipe/afm whatever works)
Plz help!
Thanks <3
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
