Anyone know of any electrician jobs paying 90k+ based in Melbourne? My current job is really giving me the shits, having to travel interstate at least a couple of weeks a month, when it should be shared around with the other tradesmen. I feel like a f**king puppet at the moment...
Just a few ideas that are going through my head at the moment. Just being overworked to the bone, when I was told that work would be shared around has really given me the irrates. Not to mention the full-blown argument that I had with both my bosses. Probably won't end up leaving, but just weighing up my options.
Might see if I can get into cruisy construction work again :)
sorry to hear juliette
hope its something simple, if there is no grinding, no chucks of cogs etc surely its something simple
on a good note all our plastering is done, finito! rangehood ready to go back in, all roof panels fixed (were sagging) and holes fixed up
tomrorow sanding mission and then undercoat and done wooohooo
Does anyone have any spare 3inch silicon hose bends? Im after a 90degree bend or 45degree bend, just want to borrow and/or buy if it fits!
My airpod sits too high and hits the bonnet, want to put a bend between the AFM and airpod so its sitting inside the vacant space where the airbox was! (or a bend between intake pipe/afm whatever works)
Plz help!
Thanks <3
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
