Fuck that is good, not like the shit you see here in AUS or more so I am yet to see a decent one in AUS.
Well, we're actually better off in oz than the guys in the US cos we can get Z31 200ZR's. Or you can just bolt an RB25/26 using a 200ZR crossmember to the Z31 ZX. Combine RB with something that looks like that and it's instant pants party time.
So I just lost 3 demerit points... The police officers "guessed" my speed by following me (from about 100m away) down a sidestreet.
Since when is that an accurate way to measure speed?!!
easiest of all fines to contest.. may as well if u need the points
Nah... If I've done something wrong then I'm always happy to take whatever I deserve.
$234 fine doesn't bother me. The demerits are a bit of a bitch though. Just means if I get caught driving my new car just once then I'm without a license :ninja:
Hey, I will be "able" to :P
yeh spose, but the you get arsefucked when your caught
Nick they look awesome! But they are a car that needs to be lowered and on some 19's. Saw a photo of a stock one, and wasn't much to look at
haha thats why i posted the to that were lowered on 19s hahaa
Biker mice
haha fark forgot about that, they were sick to
speaking of which, would said headkicker be interested in "breaking a few bones" for me? seems to be quite a profitable venture on the part of the headkickee
Are you friends with Ian at all? If he won't do it then he knows someone that will.
True, its just getting them to do it.
Hah!
You sorted out your wheels yet?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
