thought you broke up or some shit a few weeks ago?
Came to an agreement and took her back about a week ago. All is good now.
I made a real mess though. Her mum hates me now and won't let me in their house...
love watching this, the lead they create over the rest of the pack is crazy. i think they should bring back all the different cars again like bmw, subaru etc. it was so much better to watch. at the rate its going it wont even be ford vs holden its just going to be holden.
GEE TEA ARE WHOOOOOO!
don't think you did
yeah its in northern africa i think.
what did you do? cum on their cat?
Why would she care? It's not like I tapped them :( She's always alone with other guys in their cars. It's something called "trust" ;) Without it, relationships fail.
Come to think of it, I don't think a male has sat in my passenger seat for a few months :D
Drove around with 3 girls in the Supra all day today ;)
i think i needs to be your friend and hangout with you :D
Why would she care? It's not like I tapped them :( She's always alone with other guys in their cars. It's something called "trust" :D Without it, relationships fail.
no matter how trusting a girl is of her bf, him alone with another girl doesn't ever wash. I don't know a single girl who would tolerate that and a lot of them are in long term relos and married. I can't belieeeve u get away with that.
unless the girl's really scared of losing him, so agrees with whatever he does just so that she can be with him. reverse whippage, rare, but it does happen.
also loled hard at the nigeria scarves the IA is in green on a greenish background while the NIGER is in green on a white back ground. so it looked like a dude holding up a scarf saying NIGER
the racial slur you are referring to is spelt nigGer
She's always alone with other guys in their cars. It's something called "trust" :( Without it, relationships fail.
BAHAHAHAHAHAHAHAHAHA
you sir, have a lot to learn about women...
can you not TASTE the other guys in her mouth? or is that why you took her back? :P
can you not TASTE the other guys in her mouth? or is that why you took her back? :)
LOL. If it was any other girl I'd probably agree with you :( But not this one.
No point arguing here coz you guys don't know her :P
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
