i've got a quad currency cc, no fees for payment in USD, pounds, AUD and Yen. $10 extra annual fee but. Kinda worth it cos i'm buyin shit online and on yahoojp all the time.
'You have thirty minutes to move your car.'
'You have ten minutes to move your car.'
'Your car has been impounded.'
'Your car has been crushed into a cube.'
'You have thirty minutes to move your cube.'
hehe
looked into buying a cube. just quietly... it kinda sucked for daily driving (borrowed a mate's one for a week).
great if you wanna stand out. horrible blind spots, bad fuel economy, kept feeling like I was driving a van and if I crashed I was gonna get flung through the window.
so I bought a golf instead :) 7L/100km on 95 octane. diesel does 5L/100km. cbf with diesel though, accelerates like a snail. at least the 2L petrol accelerates like a turtle.
